Author Topic: RCD 510 SD Memory Card Size....  (Read 7463 times)
Offline MattPoss
« on: April 25, 2010, 09:02:12 pm »
Just wanting to double check,
Am i right in thinking that the maximum size for and SD Card is 2GB and the maximum size for and SDHC Card is 32GB?!
Also, whats the difference between the SD and the SDHC?!
Cheers in advance :happy2:,
Matt
cameluk
Re: RCD 510 SD Memory Card Size....
« Reply #1 on: April 26, 2010, 01:49:24 pm »
SD limit is 2GB
SDHC limit is 32GB for the RCD 510
Apart from the obvious difference in capacity and cost, SDHC are not backward compatible, SD readers won't read them and their transfer rates are higher
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #2 on: April 26, 2010, 02:26:27 pm »
SDHC uses a different storage system than SD, and can only cope with capacities up to 32GB, in the same way as the SD format was only capable of utilising 2GB capacity, The difference is the result of the file format used, SD cards use FAT12/16 formats, where as SDHC use FAT32, which allows for the larger storage capacity.
Details of the standard canbe found http://www.sdcard.org/developers/tech/sdhc/
Offline MattPoss
« Reply #3 on: April 26, 2010, 09:50:51 pm »
Thats great, thanks a lot lads :happy2:
Matt
