Author Topic: Swift assistance required. ED30 owners.  (Read 1252 times)
Offline QD MBE
  • -Receive: 102
« on: April 27, 2010, 07:22:26 pm »
Right,
Only for Ed30 owners with Std Pescara's and Std 312mm Brakes fitted.
I am doing some big maths to assist DaveB.  I need a measurement taking.  I need to know the measurement from the face of the Front brake disc to the inside/back face of the wheel.  It needs to be fairly precise to the nearest mm.
I am trying to work out what size spacer would be required to clear the Porker caliper behind the Pescara...................
The measurement i am after is shown below.
:drinking: :drinking: :drinking: :drinking: :drinking:
Offline 182_blue
  • -Receive: 54
Re: Swift assistance required. ED30 owners.
« Reply #1 on: April 27, 2010, 08:18:57 pm »
Do you need the lowest point ?, iirc the alloy curves on inside hence its possibly a different measurement at the top than it is the bottom (as so will middle too)
Offline QD MBE
  • -Receive: 102
« Reply #2 on: April 27, 2010, 08:21:21 pm »
Give me just the mid point, just looking for a ball park spacer figure, a point to work from in order to get 4-5mm clearance.
Offline Shaun
« Reply #3 on: April 27, 2010, 08:52:53 pm »
Hi.
Just measured mine: 55mm.
Hope that helps.
Shaun
Keep The Faith
GTI Edition 30 No. 0687 - Candy White - 5 Door - Lux Pack 1 - Park Sensors - ITG Filter - Bluefin - ECD Insert - Cruise Control
Previously: Mk1 Golf - Mk1 Jetta - Mk1 Polo Coupe - Mk2 Jetta - Mk3 Golf - Mk4 Passat - Mk1 Polo - Bora - Audi A4 / A6 / A8 - Mk3 Polo - Mk4 Golf
Offline QD MBE
  • -Receive: 102
« Reply #4 on: April 27, 2010, 09:40:35 pm »
THanks Shaun.
D
