Author Topic: jingle sound on turbo spool  (Read 5286 times)
Offline cuprak1
  • Cupra k1 - 360 bhp/360 ft-lbs
    • London web design
« on: April 28, 2010, 04:22:12 pm »
following from this thread i found... http://forums.vwvortex.com/zer...45650
My k04 is making a jingling sound when spooling almost like blades are hitting the side ever so slightly..
any ideas what it could be, cars only done 20k and  on stage 2+
SpeedStats iPhone app  - AVAILABLE NOW!
View my Cupra k1 project thread here! 360is
Offline RobH
  • Revo stg 2+
Re: jingle sound on turbo spool
« Reply #1 on: April 28, 2010, 05:40:47 pm »
Al had this but after he did the RS4 valve it went away (i think) :happy2:
Mine kinda does it but im not 100% with the car having solid engine mounts it could be anything :confused:.
Offline GTIjames
« Reply #2 on: April 28, 2010, 06:15:54 pm »
mine has been doing this for past 5 months...
its only when the engine is cold, the jingling noise starts as the boost builds up and occurs in any gear, when I take the foot off the throttle the jingling slowly stops. As soon as the car has warmed up a bit and the temp gauge is half way then it i can no longer hear it..
i had my turbo off just over a month ago when jkm fitted the forge actutor and the chap there said it looked in good nik, so I am thinking its something else
i read djhorace's post about the rs4 fuel job fixing it, so I got one just not fitted it yet so will update once its on
Offline cuprak1
    • London web design
« Reply #3 on: April 29, 2010, 10:07:10 am »
the noise went away this morn randomly... it happens hot or cold plus IIRC al still has the problem sometimes... even with the rs4 valve.
it must be boost related as its defo happening as boost builds up. i want to get to the bottom of this lol doing my head in  :jumping:
Offline PDT
  • -Receive: 142
« Reply #4 on: April 29, 2010, 03:37:02 pm »
I get this on my Revo STG2+ ED30 as well. only started once the milltek downpipe was fitted. It doesnt concern me in any way.
Offline QD MBE
  • -Receive: 102
« Reply #5 on: April 29, 2010, 07:36:26 pm »
Offline cuprak1
    • London web design
« Reply #6 on: April 30, 2010, 09:55:46 am »
Are you sure it is not pinking?
http://www.fiatforum.com/panda-classic/78229-what-exactly-pinking.html
That could be quite worrying...
a lot of things there which it could be or could of caused the noise, i guess ill have to get a few things checked over.  :scared:
Offline PDT
  • -Receive: 142
« Reply #7 on: April 30, 2010, 02:04:56 pm »
The TFSi has individual cylinder trims for ign timing so I doubt its pinking (mine sounds very similar to pinking but I know it isnt) if the ECU detected enough knock that it was audiable by ear the car would have gone into limp long before you would hear it.
If you are still concerned about it being pinking then datalog the ign pull accross all 4 cylinders.
Offline djhorace
« Reply #8 on: April 30, 2010, 05:41:11 pm »
I had jingling on mine from 15000 miles, and it was only when the RS4 valve was fitted that it went away. It was intermittent, and it was regardless of engine temperature.
Weird how a simple valve can cause such weird noises.
Offline cuprak1
    • London web design
« Reply #9 on: May 04, 2010, 11:00:26 am »
it sounds like crickets in the engine, thats how i have seen it being talked about before, it does it everytime now very annoying
« Reply #10 on: May 04, 2010, 09:18:06 pm »
Are you sure that its in the turbo. Sounds like the cam belt tensioner.  :smiley:
Offline cuprak1
    • London web design
« Reply #11 on: May 05, 2010, 09:45:39 am »
im only making assumtions as to where the noise is coming from exactly because it seems to happen after 2.5k when turb spools and the noise decreases when i let off, ill get it looked at
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #12 on: May 05, 2010, 11:41:28 am »
loose heat shield that wedges against something when you lift off?
Red ED35 5dr DSG
BLOG | BUILD
Offline cuprak1
    • London web design
« Reply #13 on: May 27, 2010, 07:55:57 pm »
noise still there :( goes away when i fill up with fuel most times...
Offline muckipup
  • -Receive: 25
« Reply #14 on: February 25, 2011, 10:37:05 am »
Bit of a thread resurrection  :ashamed: but I get exactly this (just audible to me) after a K03 to K04 conversion...I guess it is just a quirk of the K04. Glad I found this thread and that I'm not the only one as I was a bit concerned.
