brass pins checked.
thanks for the adv measuring blocks.
I had a look at that, and it showed antenna 2 having no signal whatso ever.
So, i was wondering if i had the wrong shark aerial. i think i have the phone aerial one. anyways, ive been to the breakers, got an old standard aerial base.
with the new base connected witth a whip aerial, the signal shot up.
Antenna 1 (rear window) strength was about = 75-80
antenna 2 (whip style aerial) dangling in boot = 90-95
I left the shark fin on the roof disconnected, i slimmed down the old aerial base and put it under the headlining with the whip screwed in. i also wrapped this is foam.
the signal then went down to 65-70. I have used it around town and my signal seems perfect.
I was thinking if it needed a boost i could install an amplifier, but looking in the aerial base, it looks as though there is already any amp in there??
there is plenty of circuitry etc? is that an amp in there?
