Author Topic: Reassurance sought - intermitant noise from my ED30!  (Read 6170 times)
Offline GE90
« on: April 29, 2010, 01:52:13 pm »
Right all, I would appreciate your thoughts/reassurance!
As some of you are aware, I recently bought myself a 2008 Edition 30, and have been more impressed than I ever thought I would be. It is just an excellent all round package, and certainly suits the type of daily journey I have.
However….. I have just one observation and I am really seeking some reassurance, as I am finding it unreasonably annoying! I have a slight noise at the clutch bite point, which is difficult to accurately describe. It is very intermitted, and only does it when pulling away from standstill (1st and reverse). I would describe is as a slight creak/warble (if that is a word!).
My local dealer has had the car for many days and cannot hear it, although they have inspected engine mounts etc as far as possible.
Now I know that as the clutch etc is all working faultlessly and the car still has 1 ½ years warrantee remaining I should really just forget about it. However, I ended up driving another ED30 today, and it did exactly the same (although just once over a long drive)!
Does anyone know the noise that I am hearing, and perhaps confirm that it is normal? It really needs the radio off or low the hear it.
Thanks all!
Offline joesgti
  • Eat my sick, Eat my sick.
Re: Reassurance sought - intermitant noise from my ED30!
« Reply #1 on: April 29, 2010, 02:48:20 pm »
sorry, cant be of any help mate, i dont have an ed30 but my gti doesnt do it.
Offline GE90
« Reply #2 on: April 29, 2010, 03:32:04 pm »
Thanks Joe...
After a little time on Google I have found a number of similar posts on various forums describing it as “a slight 'chugging' noise when at low revs at the biting point on the clutch”. This is probably a better description than my poor effort! It seems that it mainly affects ED30’s, possibly with no fix and assumed to be a characteristic ED30’s by dealers.
Would any fellow ED30 owners please let me know if their vehicles do something similar?
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #3 on: April 29, 2010, 03:34:02 pm »
I believe this could down to the Dual Mass Flywheel, I am sure some others with the ED30 have had this done under warranty  :happy2:
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #4 on: April 29, 2010, 03:42:36 pm »
Steve is as ever correct  :notworthy:
Mine exhibits the same 'feature', some dealers may change the whole setup if you complain enough.
I assume you dont have any other issues like clutch slip under WOT at 3000 rpm?
Its also a factor of how worn your engine mounts are and fitting ECS insert/VWR lower mount / full set of mounts can and does change how it feels.
Ultimately get your ED30 remapped, keep your fingers crossed and enjoy for x months/years but budget for a replacement clutch/flywheel/pressure plate when it eventually goes  :signLOL:
Red ED35 5dr DSG
BLOG | BUILD
Offline GE90
« Reply #5 on: April 29, 2010, 03:49:45 pm »
Thanks for your reples..
So is it a sign of wear in the DMF? I have seen reports of news cars suffering from this 'feature'. I understand that when DMF's are worn it causes vibration etc. The two dealer that have had the car both deny that their is any fault.
I have no slip or any other issues at all (fingers firmly crossed).
Offline 182_blue
  • -Receive: 54
« Reply #6 on: April 29, 2010, 04:28:14 pm »
Mine has done this from new, seems to be a DMF thing, i recently had a new DMF under warranty and a new clutch but noise is  still there LOL, i just live with it now, i tried two other ED30's and they did it too although the owner didnt notice (must be numb nuts LOL)
There was a massive thread on a USA forum and some solved it by swopping out the DMF for a single piece one.
« Last Edit: April 29, 2010, 04:30:21 pm by 182_blue »
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #7 on: April 29, 2010, 05:53:01 pm »
not necessarily a sign of wear imho , like 182_blue mine did it from new as well.
think about getting the insert / engine mount replacements  :happy2:
Red ED35 5dr DSG
BLOG | BUILD
Offline GE90
« Reply #8 on: April 29, 2010, 07:16:14 pm »
It sounds like this could be a characteristic after all then. Why only ED30's then...?
What are these inserts then? OEM or after market? Did they help with yours?
Cheers!
Offline 182_blue
  • -Receive: 54
« Reply #9 on: April 29, 2010, 07:20:20 pm »
I have heard some say the dogbone mount helps, PS as far as im aware its not just the ED30, as i said USA forums reported this and they dont get the edition 30
Offline GE90
« Reply #10 on: April 29, 2010, 07:22:54 pm »
Ah right. So is the Dog Bone mount an OEM engine or gearbox mount or an after market bit of kit? Any info/threads available?
Offline 182_blue
  • -Receive: 54
« Reply #11 on: April 29, 2010, 07:28:13 pm »
Here you go http://www.mk5golfgti.co.uk/forum/index.php?topic=393.0
its aftermarket but quite easy to do by all accounts
Offline candy turbo
« Reply #12 on: April 29, 2010, 07:42:41 pm »
my ed 30 did this too and so did the s3 but not as much , fitted ecs dog bone insert to both and it stopped it  :happy2:
Offline GE90
« Reply #13 on: April 29, 2010, 07:49:33 pm »
Any downsides? Extra noise/vibration? Sounds like it is a mount issue then? Would you mind confirming that the old bush simply comes out (as if!) and the new part fits in? I am tempted to try an OEM first if that is the case...
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #14 on: April 29, 2010, 07:59:31 pm »
the old bush doesnt come out , the ECS insert simply fills the holes/voids in the OEM mount
so you leave the OEM mount in place.
if you look at Robins review of the VWR lower mount
http://www.mk5golfgti.co.uk/forum/index.php/topic,5082.0.html
 (which does replace the OE mount),  you can see where the 'fingers' of the insert goes through)
Insert is a quick and easy way to improve things  :happy2:
Red ED35 5dr DSG
BLOG | BUILD
