Author Topic: lumpy tickover  (Read 7548 times)
Offline Russ_leeds
lumpy tickover
« on: April 29, 2010, 10:09:58 pm »
noticed when sat still sometimes the car is a bit lumpy. what i mean is it just judders now and then.
any ideas what could cause this?
cheers
Black 2007 gti, 18' monza 2, sat-nav, highline, i-pod dock, armrest, 35mm H&R springs, WALK, BCS tbe, autotech front and rear arbs, ITG maxogen, NQSBBK... and more to come
Re: lumpy tickover
« Reply #1 on: April 29, 2010, 10:15:06 pm »
Maybe coil pack on its way out.  :happy2:
Offline Russ_leeds
Re: lumpy tickover
« Reply #2 on: April 29, 2010, 10:18:20 pm »
will this be covered by warranty? if not do u know how much roughly?
cheers
Offline ub7rm
  • -Given: 35
  • -Receive: 43
Re: lumpy tickover
« Reply #3 on: April 30, 2010, 06:48:41 am »
How lumpy is lumpy?  If we're talking about a small 'shudder' every so often with no change in the revs then this is considered normal for the 2.0T ...
Sepang Blue S4 BE Avant
Offline winrya
Re: lumpy tickover
« Reply #4 on: April 30, 2010, 02:25:46 pm »
mine has a small shudder when just stated and revs are around 1200rpm which i can feel through the clutch pedal when pushed down.  The needle doesn't move and once warmed up there is no shudder at all.  This is a normal thing then?  Thing is, mine only started doing it over the past couple of months?
Offline Richn83
  • -Given: 49
  • -Receive: 85
Re: lumpy tickover
« Reply #5 on: April 30, 2010, 02:50:08 pm »
Mine also has the slight judder every couple of seconds, only just noticeable if sat completely still.  Never really worried about it, and if others have got it then probably just a standard gremlin, as I have no error codes in VCDS, and no noticeable issues under normal or heavy driving conditions.  And I went on a little blast down the A20 last night to Brands Hatch.  :driver:
Offline holepunch
Re: lumpy tickover
« Reply #6 on: April 30, 2010, 04:00:56 pm »
Sounds exactly like my car!!
Offline Russ_leeds
Re: lumpy tickover
« Reply #7 on: April 30, 2010, 05:07:17 pm »
not really that noticable, almost like some1 tapping their foot every now and then. :signLOL: doesnt always do it just sum times. car drives fine no probs just wen sat still
Offline cuzmk5
Re: lumpy tickover
« Reply #8 on: April 30, 2010, 06:41:40 pm »
 just got mine back from been in at the local dealers for the same problem.
they was unable to find a fault, they said it shudders around 1300 rpm, they have contacted vw about it and will be getting back to me next week with what there reply is.
i first noticed it a few weeks ago when the car is stationary.
Theirs no movement in the rev counter when it does it.
is this happening on ko3 and ko4 engine's?
Offline Poverty
  • -Given: 36
  • -Receive: 21
Re: lumpy tickover
« Reply #9 on: April 30, 2010, 07:45:42 pm »
injectors and coil packs are the main culprits for this is its more than just the normal 2.0TFSI "stumble"
Offline Richn83
  • -Given: 49
  • -Receive: 85
Re: lumpy tickover
« Reply #10 on: May 01, 2010, 06:59:32 pm »
mine is a K03
Offline cuzmk5
Re: lumpy tickover
« Reply #11 on: May 18, 2010, 10:03:18 am »
Had a fone call from Vw today. They seem to think that the dieverter valve is causing the shuddering on tick over. Shud be goin back in to have it changed on warranty next week. Will let you no if it sorts the problem.
Offline DanGB
  • Different
Re: lumpy tickover
« Reply #12 on: May 18, 2010, 11:18:03 am »
Misfires are 'normal' on the 2.0T even on idle, so this is what it problem is. Im not sure how it could be the diverter value when there is no boost involed?
Seat Leon Mk2 TFSI sport 4WD sleeper - Breaking
Buld thread: http://www.mk5golfgti.co.uk/forum/index.php/topic,45377.0.html
Offline cuzmk5
Re: lumpy tickover
« Reply #13 on: May 18, 2010, 07:32:11 pm »
.            This is what  I thought, when they rang me. They stay it also slighly shudders at 1300 rpm. It  Never use to do this so there must be a fault there somwhere.
Offline jonnyc
  • Herrooooo!
Re: lumpy tickover
« Reply #14 on: May 18, 2010, 07:37:13 pm »
Sounds like a vacuum leak.. Check the PCV and DV before anything else..
