Author Topic: Cornering Lights for those with fogs  (Read 7427 times)
« on: May 01, 2010, 12:19:10 pm »
The fog lights have been enabled via VAGCOM (VCDS) to that they illuminate via the steering wheel angle:
[ Invalid YouTube link ]
more info here: http://www.my-gti.com/2207
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
Re: Cornering Lights for those with fogs
« Reply #1 on: May 01, 2010, 12:23:51 pm »
Quite cool. Fiat Brava's, most new Mercs and the ok spec MK6 golfs seem to have these to name a few.
I need a new module controller to do this though :chicken:
Pete
« Reply #2 on: May 01, 2010, 12:28:55 pm »
I activated mine over a year ago and turned them off the next day. Couldn't even tell they were on. It just makes you look like you have a fog light out on the other side!
Offline Janner_Sy
  • -Receive: 113
« Reply #3 on: May 01, 2010, 01:49:42 pm »
have them on mine.  annoying when people stop you and tll you  that the car has a fog light off
« Reply #4 on: May 01, 2010, 02:24:50 pm »
one of lifes little annoyances
like when the xenon's are on the amount of oncoming traffic that like to blind you by flashing at you thinking you have highbeam on... or those in front who try to tell you the same by flashing their hazards and then turning their fogs on to get their point across  :fighting:
« Reply #5 on: May 01, 2010, 02:26:27 pm »
had them on mine for ages
« Reply #6 on: May 01, 2010, 03:06:59 pm »
I had a spot of that last night.
Just let them have the full main beam so they know the difference.  :innocent:
Offline 182_blue
  • -Receive: 54
« Reply #7 on: May 01, 2010, 04:50:29 pm »
I did it on mine a while back and cant be bothered to turn it back off LOL
Offline S2 Ant
  • -Receive: 21
« Reply #8 on: May 01, 2010, 06:44:01 pm »
Not a bad little feature this - does it make any difference for vision when cornering?
Whats needed to be able to use this feature? Can it be enabled via the Highline? Im guessing not?
Ant
Offline 182_blue
  • -Receive: 54
« Reply #9 on: May 01, 2010, 07:13:05 pm »
You can see it but hardly makes a difference LOL, you need VCDS to enable
Offline Russ_leeds
« Reply #10 on: May 01, 2010, 10:19:32 pm »
i have an 07 so guess id have to buy the module. how much are they plz?
Black 2007 gti, 18' monza 2, sat-nav, highline, i-pod dock, armrest, 35mm H&R springs, WALK, BCS tbe, autotech front and rear arbs, ITG maxogen, NQSBBK... and more to come
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« Reply #11 on: May 01, 2010, 10:30:24 pm »
Pete
Offline Russ_leeds
« Reply #12 on: May 01, 2010, 11:43:13 pm »
cheers so did u find out how much the new module is?
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« Reply #13 on: May 01, 2010, 11:48:32 pm »
£245.66 for the module (3C8 937 049 AB) but I didn't get a quote for fitting. I don't think it'd be cheap, probably a day at a guess?
Ring up and ask as I'd be intrigued to know tbh.
This is what you have to do to fit the controller however;
http://furmanka.blogspot.com/2007/01/mk5-kontroler-elektryki-j519-central.html
HTH  :happy2:
Pete
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #14 on: May 02, 2010, 05:27:05 am »
Only about 18 months behind the curve VC  :signLOL:
http://www.mk5golfgti.co.uk/forum/index.php/topic,140.0.html
Stu...
