Author Topic: Clutch slipping plus questions  (Read 6442 times)
Offline scotta
  • Edition 30
« on: May 03, 2010, 09:35:10 am »
Clutch has started to slip between 3 - 4k in 4/5/6th. Car has only done 19.5 k!
Anybody know prices/options for replacements?
Running bluefin stage one at the moment - is it worth sticking the standard map back on?
Could i chance it with a warranty claim if i stuck the standard map back on?
When you return the bluefin to standard does it flash the vag code back on or is it a superchips emulation of standard mode?
Any comments/suggestions welcome.
 :sad1:
Re: Clutch slipping plus questions
« Reply #1 on: May 03, 2010, 09:38:35 am »
it will not slip in stock mode as the torque is what is making it slip so you will have to spend you money on a sachs clutch disc  :sad1: but then it will never slip again
Offline subaru26675
« Reply #2 on: May 03, 2010, 10:35:09 am »
you have pm  :happy2:
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #3 on: May 03, 2010, 12:27:16 pm »
does it only slip under WOT or normal driving also?
Offline scotta
  • Edition 30
« Reply #4 on: May 03, 2010, 01:49:33 pm »
Yep only on full bore!
Ive refalshed it back to standard and taken it a run - no issues on standard even on full bore up hill.
Was thinking i might have a word with superchips and see if they have a map with abit less peak torque further up the rev range? Anyone know if this is possible?
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #5 on: May 03, 2010, 02:02:56 pm »
deffo possible, its either that or just shift down so you are above 4k rpm when giving it the beans
Offline scotta
  • Edition 30
« Reply #6 on: May 05, 2010, 12:41:34 pm »
Got quoted £580 for an oem replacement clutch fitted including vat. :confused:
Offline robern2
« Reply #7 on: May 05, 2010, 01:32:51 pm »
I paid £780 for a Helix clutch fitted inc new release bearing.
The Helix is comparible to the Sachs item discussed on this thread.
Offline scotta
  • Edition 30
« Reply #8 on: May 05, 2010, 01:53:26 pm »
Spoke to superchips who have just sent me a different map to try with a less aggressive torque delivery. Will give it a bash later on tonight and see how it goes.
Saint Steve
« Reply #9 on: May 05, 2010, 02:45:27 pm »
You may not like it. I didnt :sad1:
Went back to the Full fat version :smiley:
It will only get worse over time if your running any sort of map. So as Matt said, start saving up for the Sachs.
Offline scotta
  • Edition 30
« Reply #10 on: May 05, 2010, 03:48:11 pm »
Hmmm will see how it goes! Did you have to flash it back to standard first before installing the Diet version?
Offline joesgti
  • Eat my sick, Eat my sick.
« Reply #11 on: May 05, 2010, 03:58:51 pm »
has anybody had any experience or hurd of a clutch slipping on a KO3??
Offline chungster
« Reply #12 on: May 05, 2010, 04:34:34 pm »
yup. All depends on which brand of OEM clutch you have. If you have a LUK one then start saving for a replacement.
Offline wigit
  • -Given: 129
  • -Receive: 42
« Reply #13 on: May 05, 2010, 04:35:13 pm »
 :surprised:
Offline joesgti
« Reply #14 on: May 05, 2010, 04:40:12 pm »
how do i know?? my cars an 05?
whats the symptoms
