Author Topic: Next mod? New tyres :)  (Read 34917 times)
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
Re: Next mod?
« Reply #30 on: May 06, 2010, 07:32:49 am »
Excuse my ignorance Mike whats a RS4 valve? and the benefits.
when you are running an uprated fuelpump and software requesting 130bar of fuel pressure you have problems with the stock fuel pressure regulator valve as its limit is 127bar, rs4 valve has a limit of 132bar  :happy2:
I see you have S3 injectors mate, much benefit?
I'll know after this weekend when i get the valve fitted  :wink:
Over the top mod list ;o)
Re: Next mod?
« Reply #31 on: May 06, 2010, 07:36:12 am »
Are you APR software? Let me know what difference the injectors make, if any :)
Offline keith
Re: Next mod?
« Reply #32 on: May 06, 2010, 02:33:42 pm »
I enquired about the S3 injectors but I was told not to bother.
does anyone have the part number for the RS4 valve?
  • -Given: 243
  • -Receive: 154
Re: Next mod?
« Reply #33 on: May 06, 2010, 03:52:47 pm »
depends what software you want  :smiley:
as i wanted APR, s3 was the way to go. perhaps if (when) i go APR stage 3 or similar and custom coding i will consider rs4 injectors.  :happy2:
rs4 partnr. 079130757
Offline KRL
  • -Receive: 29
Re: Next mod?
« Reply #34 on: May 06, 2010, 04:09:10 pm »
Remeber APR make there own injectors as well but they are only available with stage 3.
  • -Given: 243
  • -Receive: 154
Re: Next mod?
« Reply #35 on: May 06, 2010, 04:24:58 pm »
i know but as i want to have pistins and rods done at the same time, i can't use apr sw
Offline KRL
  • -Receive: 29
Re: Next mod?
« Reply #36 on: May 06, 2010, 05:15:01 pm »
Don't really follow?  APR recommend uprated rods for their stage 3 100 octane file so why would uprating the rods and pisotns be a problem?
  • -Given: 243
  • -Receive: 154
Re: Next mod?
« Reply #37 on: May 06, 2010, 05:20:55 pm »
no problem as long as you only change rods and keep stock comp. but other pistons i assume the software won't be app
licable  :confused:
Re: Next mod?
« Reply #38 on: May 06, 2010, 05:31:38 pm »
A different compression ratio would require different software to allow for the different volume, timing and fuelling. The APR software would still work, but it wouldn't be as effective :smiley:
Re: Next mod?
« Reply #39 on: May 06, 2010, 05:55:17 pm »
^^^^ There speaks a man who knows about such things  :happy2:
  • -Given: 243
  • -Receive: 154
Re: Next mod?
« Reply #40 on: May 06, 2010, 06:31:39 pm »
my own thoughts.
My reasoning is why go stage 3 over my current K04+ for app. 50bhp and no more torque??
if i go stage 3 i want more torque aswell  :happy2:
Offline KRL
  • -Receive: 29
Re: Next mod?
« Reply #41 on: May 06, 2010, 07:04:25 pm »
Check out APR's stage 4 development.  That may want to make you go stage 3 and the stage 4  :evilgrin:
Re: Next mod?
« Reply #42 on: May 06, 2010, 07:13:04 pm »
Nah! What about Stage 6, you power-mad maniacs!  :evilgrin:
Offline pako88268
  • Always driving slowly =)
Re: Next mod?
« Reply #43 on: May 07, 2010, 07:40:27 pm »
HEy mike
what WOT box are you looking for?
REVO Stage 2+, Dbilas intake, KMD High Pressure Fuel Pump, Sachs organic clutch, Sachs Single Mass Flywheel, BSH Oil catch tank, BSH Engine mount, BSH transmission mount, BSH lower mount, Milltek downpipe, 200 cells cat back, HKS Turbo Timer, FORGE DV Valve, FORGE Spacer, THS -intercooler, OZ, etc
Re: Next mod?
« Reply #44 on: May 12, 2010, 12:04:29 pm »
Managed the RS4 valve, BSH PCV Fix, WALK, BSH mounts and aircon condenser out last week/week before, also fitted td 1.2s
Sooooo, before I go back to Germany in the next few weeks its looking like my choices are;
2 Tyres - 888, R1R, Hankook etc - (have worn vreds atm)
Sachs pressure plate to compliment sachs disc, (£260 fitted)
WMI, (£350 fitted)
Forge actuator (£275 fitted)
or open to suggestions.  Im thinking about waiting 'till I come back and end of Aug having another mod spree....
« Last Edit: May 12, 2010, 12:07:22 pm by Tfsi_Mike »
