Author Topic: Odd brake wear pattern advice needed....  (Read 3655 times)
Offline Richn83
  • -Given: 49
  • -Receive: 85
« on: May 05, 2010, 11:45:30 am »
Hi All, After a bit of advice, i have a funny wear pattern which has appeared on my front left near side disk.  Wanting to know if I should give it some attention or not?
Car doesnt feel odd under braking, and I have no warning lights or error codes, all your time comments and help will be greatly appreciated.   :notworthy:
I thought this could initially have been a inconsistency in either the pad or disk that would wear away, but after a couple of hundred miles it hasnt changed.
So what do we reckon........
And before any one says I know I need to replace the nasty looking nut covers!!!!  :ashamed:
Offline tony_danza
  • -Receive: 112
Re: Odd brake wear pattern advice needed....
« Reply #1 on: May 05, 2010, 12:17:37 pm »
Black looks like pad material, as if it isn't seated quite square and it is ever so gently rubbing.
Sideways yo!
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #2 on: May 05, 2010, 01:54:22 pm »
hard to tell from the pics, but it looks 'blued' from overheating from a high spot.
Def worth having the lot off for a check and maybe some cleanup with sandpaper  :happy2:
Red ED35 5dr DSG
BLOG | BUILD
Offline mk2mexico
« Reply #3 on: May 06, 2010, 08:18:10 am »
Take off the break pads and place a sheet of sandpaper on a flat surface it must be totally flat and smoothe.
with the pad in your hand move the pad with braking material facing down on to the sand paper in a figure of 8 motion this should square things up and remove all the high spots  on the pad.
do not go mad only take off a light skim until the surface looks clead and even
replace in to caliper and try again. put some copper grease on the moving parts and area
good luck  :happy2:
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #4 on: May 06, 2010, 08:42:33 am »
Cheers John o and mk2mexico, will try and make time to do this on the weekend, not taken the pads out on a car before will I need any specific tools for winding the pistons back or will replacing the same pad negate this requirement (I do have the haynes manual for the mk5) so hopefully this will have a step by step in it!
thanks again  :drinking:
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #5 on: May 06, 2010, 11:12:51 am »
...........& get those new nut covers,only around £6-8.00 a set. :signLOL:
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #6 on: May 06, 2010, 12:06:44 pm »
Yes Gene  :sad1:  Sorry..... they are a complete disgrace  :ashamed:
.......Rich goes off to ebay to buy the ones he's been watching.......
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #7 on: May 06, 2010, 12:11:53 pm »
given that you are removing a small amount of pad material . no need for a tool to wind back.
be interesting to see why its like that as its unusual, you may even have the opposite and a chunk of pad missing.
and also having a look at the other side of the disc.
Red ED35 5dr DSG
BLOG | BUILD
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #8 on: May 06, 2010, 12:32:44 pm »
Cheers John o will try and get it up on axle stands so I can get a look at the back side of the disc, and will see if I can get photo's showing whats going on.
Now to convince the girlfriend that this is necessary work to be carried out on Saturday on the grounds of safety!  :rolleye:
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #9 on: May 06, 2010, 12:36:51 pm »
...........good man.Got mine from there as mine were the same as your's when i picked it up. Alloy wheel cleaner does it.  :happy2:
