Author Topic: Jabbalad's Candy white Edition 30 build thread  (Read 86142 times)
Offline jonnyc
  • Herrooooo!
Re: Jabbalad's Candy white Edition 30 build thread
« Reply #30 on: May 07, 2010, 06:12:17 pm »
Just been doing some measuring if anyone's interested...
Compressor Wheels:
K03 - Inducer 41mm / Exducer 53.4mm
K04 - Inducer 46.3mm / Exducer 59.2mm
TD K04 Hybrid - Inducer 49.5mm / Exducer 65.5mm
Haven't measured turbine wheels.
There's no difference between K04 and K04 Hybrid anyway except the blades are cutback.
Kev
So is that the K24 wheel? Or did they go with billet HTA?
Offline jabbasport
« Reply #31 on: May 07, 2010, 06:16:01 pm »
K24 wheel..
Kev
Follow us on Twitter
Offline Janner_Sy
  • -Receive: 113
« Reply #32 on: May 07, 2010, 06:25:21 pm »
Should think Luke will be fitting this weekend along with RS4 pressure regulator and de-cat. Possibly some W/I :)
Kev
Oops, looks like you made a typo there, let me just correct that for you
Should think Luke will be fitting this weekend along with RS4 pressure regulator and de-cat. Possibly WITH some W/I :)
Kev
There, thats better  :happy2: :grin:
I have a question though, how will the water meth be controlled in the event of runing out of mixture as your map is not switchable.  is there some way of it automatically adjusting the timing or boost etc
Sy :happy2:
Offline jabbasport
« Reply #33 on: May 07, 2010, 06:27:42 pm »
In the worst situation the ecu would detect the change and the ignition timing would be pulled back.
But for Lukes i plan to utilize the lower octane coding built into the ecu and switch via VCDS for when the W/I isn't being used..
All kits now come with low level indicators as standard if you're using the supplied bottle and there is the option of a Safe Injection unit which drops boost if the flow drops..
Kev
« Last Edit: May 07, 2010, 06:31:33 pm by jabbasport »
Offline jonnyc
  • Herrooooo!
« Reply #34 on: May 07, 2010, 06:47:21 pm »
K24 wheel..
Kev
 :smiley: Thanks Kev, look forward to your results.. Great to see someone trying new things!  :congrats:
Offline Janner_Sy
  • -Receive: 113
« Reply #35 on: May 07, 2010, 06:51:35 pm »
K24 wheel..Kev
:smiley: Thanks Kev, look forward to your results.. Great to see someone trying new things:congrats:
I was having a chat with TFSI_mike the other day, and we both agreed that its about time some real tuning started occuring.. Everything so far seems to be generic maps and normal bolt ons.
Offline jabbalad
    • Jabbasport
« Reply #36 on: May 07, 2010, 11:22:21 pm »
K24 wheel..Kev
Means alot dude, as a company we have alwase been about evolution, and doing it our own way!
This hybrid is just the beginning for us on the 2.0 tfsi though :wink:
Anywho, the turbo is all on the car now  :jumpmove:
Pics will follow tomorow when i have done the last couple of bits!
Been trying to do all the bits after work as its been a bit manic trying to fit in a re shell of a customers MK2 race car around all the other big turbo/ engine builds we have here at the min.... hey ho its all good fun tho  :laugh:
12.7 santapod... soon to be quicker :-)
Candy White Edition 30; Custom KW clubsports, Eibach hollow arbs, Jabba remap, BTB Exhaust, Twintake, Autotech HPFP, Team Dynamics wheels, VWR Big Brakes.
Offline Janner_Sy
  • -Receive: 113
« Reply #37 on: May 07, 2010, 11:44:40 pm »
YOu reckon you'll get her mapped this weekend then?
What about for guys with the little k03 urbos then, I heard about a hybridized option for the k03 a while back?
« Last Edit: May 07, 2010, 11:47:24 pm by vRSy »
Offline jabbasport
« Reply #38 on: May 08, 2010, 09:30:42 am »
Yeah, we'll be looking into hybrid K03 options next, we've got one sat on the shelf here that i think we'll be sending over to Turbo Dynamics for some development.
I reckon we could put a K04 wheel in a K03 housing and do around 300-310bhp.
Kev
« Reply #39 on: May 08, 2010, 09:46:28 am »
Just putting my nan on eBay... Will swap for hybrid ko4 & map
I have to try and wait untill the hybrid / mapping is adequately road tested. Be a nightmare If there was
to be a silly niggling problem when I got back to Germany soon :(
Offline Janner_Sy
  • -Receive: 113
« Reply #40 on: May 08, 2010, 10:39:42 am »
Kev
:party: :party: :party: now that would grab my attention more than a k04 for some strange reason 310hp with very little lag and then maybe some WMI as well.  Presumably would require injectors though?
Offline jabbasport
« Reply #41 on: May 08, 2010, 11:05:37 am »
No problem, Luke's going over to the ring as he says middle of this month so as soon as it's mapped it's doing at least 1000 miles and some hard miles around the ring. :)
Yeah, i'd say you'd need injectors to be safe, just some K04 injectors though.
We haven't got any K03 cars of our own so will probably looking for a Guinea pig at some time soon :)
Kev
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #42 on: May 08, 2010, 02:08:56 pm »
but there is already a "hybrid" out for the k03 engines, basically a k04 for straight swap k03 fitment  or am I wrong?
Offline yin
  • -Given: 77
« Reply #43 on: May 08, 2010, 02:10:54 pm »
http://www.owendevelopments.co.uk/news/story.asp?newsId=95
"which will be a bolt-on turbo upgrade for the K03 turbo engines used in the MkV VW Golf GTi, SEAT Leon, Skoda Octavia and Audi A3"
this is one i think
« Last Edit: May 08, 2010, 02:13:38 pm by yin »
Offline Janner_Sy
  • -Receive: 113
« Reply #44 on: May 08, 2010, 03:07:23 pm »
yeah but as far as im aware it also requires a DV relocation therefore different intakes, TB/IC pipe new DV mounting kit etc so not as bolt on as it seems.
