Author Topic: RNS 510 again  (Read 1893 times)
Offline Dai-Click
RNS 510 again
« on: May 05, 2010, 08:38:23 pm »
Hi,  I know this has been done to death but I am trying to get a definative, 100% answer as to the version of CAN gateway needed to ensure no battery drain issues when retro fitting a RNS510.  I have a March 2007 ED30 with Can Gateway "K" according to VCDS scan. I managed to clear all the faults after fitting but have 1 question.
In this topic
http://www.mk5golfgti.co.uk/forum/index.php/topic,8222.0.html
answer #2 states that "K" or above will be OK - is this correct?? as I'm sure I have read elsewhere that it needs to be at least "L"
Any advice would be appreciated as I would like to upgrade from SW 1100 to SW2680 for the extras but don't want to run into battery problems as I don't use my car every day.
Dave
Offline Ron, Edition30
Re: RNS 510 again
« Reply #1 on: May 05, 2010, 08:57:14 pm »
No problems for me. I have k version gateway with B revison RNS-510 (HW:11) retrofitted. Originally running fw 1120 and now running 2680 for a few months now with no battery drain problems.
I had a similar thread a while ago.
http://www.mk5golfgti.co.uk/forum/index.php/topic,10902.msg168082.html#top
Ron
Edition30 - Reflex Silver - 3door - Manual - Highline - RNS-510 - Unmodified - No.1097
Offline Dai-Click
Re: RNS 510 again
« Reply #2 on: May 05, 2010, 10:02:16 pm »
Ron,
thanks for that - looks like I'll give it a go.
Did you lose Maps & music when you upgraded to 2680?
Where did you get the updated fw?
Dave
cameluk
Re: RNS 510 again
« Reply #3 on: May 05, 2010, 10:10:13 pm »
There are a couple of working download links if you search my-gti.com
Offline Dai-Click
Re: RNS 510 again
« Reply #4 on: May 06, 2010, 09:16:00 pm »
Thanks for your replies - I have downloaded the 26XX firmware and burnt to a CD so just have to go for it :scared:
Will the unit switch itself off after 30 mins or will it stay on till the upgrade is finished,  I believe that takes some 50minutes
How do I ensure the RNS stays on without the ignition on for long enough?
David
cameluk
Re: RNS 510 again
« Reply #5 on: May 06, 2010, 09:24:28 pm »
RNS will know the firmware is being updated and won't turn off until it needs to reboot itself
