Author Topic: mmm....  (Read 1385 times)
Offline stuupnorth
    • stuupnorth
mmm....
« on: May 06, 2010, 08:05:18 pm »
Hi guys
Has anyone heard of this problem before??
Was told my local garage that the misfire i had was due to a faulty
ignition coil it was changed and then the guy said the car won't start!!!
the dealer has now said the ecu might need to be reset or at worse a new ecu!!!
Offline xxx_mojo_xxx
  • MUBster DUBster
Re: mmm....
« Reply #1 on: August 15, 2011, 10:24:59 pm »
Did you get this sorted?
Offline audiag
Re: mmm....
« Reply #2 on: August 22, 2011, 01:57:25 pm »
Any joy with this????
Offline mark01348
Re: mmm....
« Reply #3 on: August 24, 2011, 01:07:40 pm »
I've seen fuses blow after faulty coils causing non start. May be worth a check
