Author Topic: URGENT Help needed please  (Read 7905 times)
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« on: May 06, 2010, 11:54:12 pm »
We have a car on our ring trip running this fault: -
16471/P0087/000135 - Fuel Rail/System Pressure: Too Low
It's pulling back the power above 4000rpm at higher speed.
Any ideas??
A quick bit of logging following the guide on Ross Tech wiki shows the requested pressure isn't being meet about 4k rpm by upto 10bar.
Offline G4V VW
Re: URGENT Help needed please
« Reply #1 on: May 07, 2010, 12:02:10 am »
Not much help but same fault code on another vehicle on another forum was HPFP faulty!!
« Reply #2 on: May 07, 2010, 12:03:42 am »
Cam follower is the obvious one (and easiest to eliminate as a cause)
The more worn it is the higher the failure to reach requested rail pressure.
Stock fuel pump or HPFP? - could be the pump failing.
How is everything else? idle okay? Misfires?
Offline PDT
  • -Receive: 142
« Reply #3 on: May 07, 2010, 12:08:31 am »
Need to know the following:
Engine type
mods
post the logs up ( or email them to me at: sales@pdtuning.com)
Offline G4V VW
« Reply #4 on: May 07, 2010, 12:08:41 am »
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #5 on: May 07, 2010, 12:09:41 am »
It's a normal GTI with a stock pump running with Stage 2 code.
K&N panel in standard airbox.
Will check the follower first thing  :happy2:
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #6 on: May 07, 2010, 12:12:13 am »
Logs on the way PDT  :notworthy:
Offline PDT
  • -Receive: 142
« Reply #7 on: May 07, 2010, 12:28:09 am »
No log arrived?
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #8 on: May 07, 2010, 12:40:35 am »
Should be now  :smiley:
Offline PDT
  • -Receive: 142
« Reply #9 on: May 07, 2010, 12:54:22 am »
Got the logs but dont show much, I have replied by email with some tips on logging and what I need to graph them correctly. Once I get them through I will check them over and send a reply to you  :happy2:
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #10 on: May 07, 2010, 12:56:10 am »
Thanks David  :happy2:
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #11 on: May 07, 2010, 05:46:40 am »
could be the sensor sitting on the side of the hpfp, known fault and apr recommended me changing it as part of error elimination.
Over the top mod list ;o)
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #12 on: May 07, 2010, 08:35:48 am »
A quick test with a known good working low pressure fuel sensor "appears" to have remove the fault, so a replacement is currently being collected.
  • -Given: 243
  • -Receive: 154
« Reply #13 on: May 07, 2010, 01:13:34 pm »
they one on the hpfp??  :smiley:
Nick S
« Reply #14 on: May 07, 2010, 01:40:43 pm »
Interested to know the results of this mine is doing the same
