Author Topic: Ed30 owners with cruise - question  (Read 3235 times)
Offline Smudgster
« on: May 07, 2010, 09:20:11 pm »
when you switch cruise does the green cruise light illuminate on the dash. Mine only lights up when i actual set cruise!!
Offline cuzmk5
Re: Ed30 owners with cruise - question
« Reply #1 on: May 07, 2010, 09:25:31 pm »
when switch on the stalk is set to on, it brings the green light on the dash and stays on until you until you move the switch to off.
Offline Moschops
  • -Given: 118
  • Edition 30 No 2275
« Reply #2 on: May 07, 2010, 09:35:43 pm »
As above... :happy2:
Cheers,
Wayne
Offline Smudgster
« Reply #3 on: May 07, 2010, 09:48:49 pm »
thought so, mine must be coded wrong sh*te  :signLOL: :signLOL: :signLOL: :signLOL:
thanks guys
Offline WhiteGTI
  • F-A-S-T
« Reply #4 on: May 07, 2010, 09:51:59 pm »
Errr?
If i switch cruise "on" with the stalk by sliding the little switch then no light appears. If i press "Set" to set the cruise to the current speed, it will turn on the cruise control and the green light will appear. If i put the clutch in/brake then the light goes out. VW fitted my cruise.
2006 E46 BMW M3 - 343hp
Offline boe3
« Reply #5 on: May 07, 2010, 10:08:10 pm »
As above this is the correct operation
« Reply #6 on: May 07, 2010, 10:17:08 pm »
Errr?
Wot he says.
jacko78
« Reply #7 on: May 07, 2010, 10:20:56 pm »
Guys your all right I've had this on both my last cars the last car with cruise only illuminated when I set a speed, my current car is on as soon as I flick the switch. So don't panick and relax it's only a commercial
Offline Smudgster
« Reply #8 on: May 07, 2010, 10:27:24 pm »
Cheers guys
My 07 plate GTi - light came on when you switched cruise on
My 08 Ed30 - Lights come on when cruise speed is set not when cruise is switched on.
Just wanted to check
Smudge
Offline 182_blue
  • -Receive: 54
« Reply #9 on: May 08, 2010, 08:00:09 am »
Errr?
Mines like this
Offline Thor
  • -Receive: 25
« Reply #10 on: May 08, 2010, 08:23:46 am »
Errr?
Mines like this
+1 also factory fit :happy2:
                                     Mk6 GTI
Offline Moschops
  • -Given: 118
« Reply #11 on: May 08, 2010, 10:04:06 am »
I will check on my way home tonight.... :laugh:
Cheers,
Wayne
Offline Vick N
« Reply #12 on: May 08, 2010, 10:27:32 am »
Mine is also like this and fitted by VW Dealers!  :drinking:
Vick  :smiley:
Offline Golfgirl
« Reply #13 on: May 10, 2010, 05:17:20 pm »
Errr?
Mines like this
Mine is like this and retro-fitted :happy2:
FOR SALE!
Offline gtineal
« Reply #14 on: May 10, 2010, 08:39:34 pm »
 as above , factory fitted    :wink:
