Author Topic: Detailing Help Req'd!, and car needs some TLC  (Read 5952 times)
Offline Janner_Sy
  • -Receive: 113
« on: May 09, 2010, 08:48:38 pm »
right, im not really in he know when it comes to detailing a car, ive always been a as long as its shiny im happy kinda bloke.  so apart from one pro detail in the last 3 years, the car has always been washed in the drive through polish jet/handwash garages.  Usually found every few miles along each road in kent.  I have also been known to use a drice through car wash from time to time.
So apologies for al the abve, i need converting and institutionalising into the detailing way of life.
Parked my car outside my house last night under a tree, and this morning the whole car was covered in sap beyond belief.  So i got the car washed and after i took a look at the paint work and to be fair even i can see it leaves a lot to be desired
Now I don’t own anything more exotic than a hose, sponge and a bucket.
Im thinking of getting myself a pressure washer, and kitting myself out with a load of detailing kit.
Can you guys equip me with the stuff I would require.  Obviously Im a complete noob to this so would need an explanation of  what they ate used for and how.
here some pics of the paint work.  I cant really see any of these swirls or anything, however you can see where he drive through wash has scratched the paint work :sad1:
Cheers guys
« Last Edit: May 09, 2010, 09:09:02 pm by vRSy »
  • -Receive: 291
Re: Detailing Help Req'd!, and car needs some TLC
« Reply #1 on: May 09, 2010, 09:17:33 pm »
I'd recommend starting off with a professional detail. It gives a good base. There are plenty of online shops to buy stuff from and even halfrauds has some half-decent stuff if you pick the right products.
Offline Janner_Sy
  • -Receive: 113
« Reply #2 on: May 09, 2010, 09:24:54 pm »
i probably will do that, but i still want to kit myself out if you know what i mean.  just need a billy basic starter pack of some sort.  plus reccommendations on what clay bars, cleaning products, sponges/clothes etc.
Offline Tuffy
« Reply #3 on: May 09, 2010, 09:39:24 pm »
Hello mate.
First thing is to ditch the drive throu hand wash places! you'd be better off letting a monkey with a wire brush clean it!
Then get yourself a couple of nice clean buckets, one for your wash solution the other to rinse out whatever your washing the car with after each panel,
I would use a lambs wool mitt to avoid the dreaded swirl marks.
Probably best to clay the car to get rid of all the road grime etc
Rinse car again
Then a large microfibre towel to dry the car off.
Treat the car to a polish something middle of the road like AG super resin ploish
Top with a seal such as jetseal
Finish off with a natural wax
This is just skimming the surface really but not a bad for a start.
Regarding the scratches you already have reckon they will need to machine polished out
All the hints and tips you will ever need are here buddy :happy2:
http://www.detailingworld.co.uk/forum/index.php
Offline Janner_Sy
  • -Receive: 113
« Reply #4 on: May 09, 2010, 09:46:01 pm »
much appreciated mate.
I was thinking hose scratches look like they have gone down past the paint, so maybe it would be possible to cover with a small paint pen, and then seal it with polish!!!!
ill have a look through that link mate
Offline Tuffy
« Reply #5 on: May 09, 2010, 09:57:21 pm »
If its just been scratched with a hose i would think they might polish out mate.
One way to see is to run your nail opposite to the way the scratch is running if you cant feel it chances are they will polish out.
If your nail catches the scratch you probably wont.
Meguires do a good starter clay kit complete with lube. your head will spin and wallet shrink with the amount of products available to keep your car lookin tip top :happy2:
  • -Receive: 291
« Reply #6 on: May 09, 2010, 09:57:43 pm »
Read the guide at the top for a start.
Detailing can get pretty expensive and I've already spent £600 before getting everything I wanted/needed. You can waste a lot of money on different products since everyone has a personal choice on what to buy. Halfrauds has a lot of stuff but most of it is crap - there are a few good products though. Also, detailing can vary from doing just basic stuff that takes 3-4 hours to detailing that takes 2-3 days, depending on how far advanced you want to go.
Here's what I would do, with the products I would recommend. Other forumites will have different opinions.
Washing: Hold off with a pressure washer. You don't need one, it's just nice to have. A simple hosepipe will suffice now and if you really get into detailing, you can research and buy a pressure washer later. Two buckets and a microfibre washmitt is enough here. Keith from the washshop has a deal on at the moment on two buckets and a gritguard. You definitely need two buckets, a washmitt and a shampoo. If buying from halfrauds, megs gold class shampoo is pretty good. I like to use dodo juice born to be mild - very slick and smooth to use.
Drying: Go for a nice drying towel, something large that you can use. I went for Chemical Guys Miracle Dryer towels.
Claying: Highly recommended. Will remove whatever bonded contaminants that weren't removed by washing. Halfrauds do a nice Meguiars Smooth Surface clay kit which is awesome. Search here on how to use it.
Polishing: Something I would recommend you get done by a professional the first time, until you are serious about it. If you go down the machine polishing route, look for the Meguiars G220 or Kestral DA6 polishers. Get one with a kit so it has polishes and pads too. Hand polishing is best done using something like Autoglym Super Resin Polish from halfrauds. This fills in light scratches.
Sealant: This essentially seals in the finish. JetSeal109 is recommended. I don't bother with this bit.
Glaze: This improves the appearance of the paintwork and prepares it for waxing. I use dodo juice lime prime lite. The standard lime prime version has a light polish in it and can be used instead of polishing, again for light scratches only.
Wax: You can spend anything from £10 to over £1000 depending on what you want. For durability, I'd recommend Collinite 476s. This is a hard wax and there's a bit of work involved but the wax can last for 3-4 months, longer if you apply a second coat. I use this in winter. There are other waxes that can enhance the blue colour. Autoglym HD wax from halfrauds is also very good.
Wheels: Megs hot rims is my choice of wheel cleaner from halfrauds, but bilberry wheel cleaner from online. If the latter, buy a spray bottle with a foaming head since bilberry comes in a concentrated form and you need to dilute it down to use. If you want to, you can clay the alloys wheels, polish them and apply a wheel sealant such as poorboy's wheel sealant. Once this has cured, dirt should simply just wash off and you won't need to use a cleaner for a while.
Tyres: I love megs endurance tyre gel. Use a sponge to apply this. Makes the tyres look new.
Windows: Clay the windows. Use Autoglym fast glass and a proper glass cloth. Both can be obtained from halfrauds.
Trim: Autoglym bumper car for the black plastic bits of the car.
Exhaust: Use a microfibre cloth and autosol metal polish (also halfrauds) and lots of elbow grease.
Order that I would do it in:
Rinse with hosepipe
Shampoo using two-bucket method. Rinse. Repeat if required.
Wash your wheels.
Whilst still wet, clay the bodywork and the windows.
Dry using a drying towel.
Apply your polish at this stage.
Apply your glaze/sealant.
Apply your wax. Leave to cure.
Do the windows and plastic trim next.
Don't forget your tyres and exhaust (I've always done them last).
  • -Receive: 291
« Reply #7 on: May 09, 2010, 09:58:31 pm »
+1 for detailingworld. It's where the amateurs and professionals alike flock to.
Offline Janner_Sy
  • -Receive: 113
« Reply #8 on: May 09, 2010, 10:06:18 pm »
cheers guys, and stealthwolf for that last post.  very informative.  And will sort m out for he beginning.  I can gt trade discount in halfrauds soi can pick up loadsa kit from there.  Ill look for the brands you mntioned aswell :happy2:
Offline B3n
  • -Receive: 29
  • Boom!!!!
« Reply #9 on: May 09, 2010, 10:08:19 pm »
Hmm the thing with asking what detailing products you should buy is if you ask 100 people youll get a 100 different answers as your just getting started ill keep it simple.
Here's my 2p
Shampoo
Meguiar's nxt or Megs hyper wash are my personal favourites tried Dodo Supernatural and i found it a pile of masturbation fluid.
Megs sheepskin wash mitt
2 buckets with grit guards supllied by Keith on here
Drying towel - ditch the chamois and get yourself a fluffy drying towel Keith on here is also selling these at the mo.
Clay bar - Just get yourself the Megs quick clay kit available in Halfords it comes with everything you need
Polish/cleanse - Autoglym Super Resin polish is a very good starting point
Wax/Sealant - Now this is where it gets confusing but if i was only allowed to use one for the rest of my life it would by Collinite 476 this stuff gives a really good finish and a properly applied layer should last for months plus its only about £12.
Ontop of the above get yourself a few microfibre cloths and foam applicator pads for applying and removing products.
Ive kept the list ive given quite straightforward and simple and the items above minus the Collinite and Megs hyper wash are either available on here or from halfords.
Dont get sucked into the world of detailing and end up spending lots of money on unneeded products and so called miracle waxes trust me ive got over £800 worth of cleaning stuff :ashamed:. 99% of a cars shine and reflection is created at the polish/Cleanse stage and at this stage a properly applied £5 product will give a better finish than a slapped on £50 product.
Start with the basics then when YOU can see areas for improvement add or upgrade products or stages such as glazes and foam.
Ben
P.s sorry if the above seem mumbled or didnt make any sense its because ive had a few cans tonight :drinking:
« Last Edit: May 09, 2010, 10:15:15 pm by B3n »
Offline Tuffy
« Reply #10 on: May 09, 2010, 10:13:32 pm »
Rinse with hosepipe
Wash your wheels.
Man after my own heart!  :signLOL:
Offline Janner_Sy
  • -Receive: 113
« Reply #11 on: May 09, 2010, 10:21:15 pm »
cheers guys.
there is no danger of me going nuts with detailing.  money burns a hole in mypocket between the  house, mods and my drinking hobby.
How often do you 'detail'  the car.  I mean if i was to do a full detail as shown above, and then the car got a bit dirty, do you detail again or just a quick wash and shampoo.  would the polish and wax required again
Offline B3n
  • -Receive: 29
  • Boom!!!!
« Reply #12 on: May 09, 2010, 10:44:05 pm »
A full detail probably about twice a year
Wash about twice a week with a qd of red mist every fortnight
Re wax probably every 2-3 months
Offline Janner_Sy
  • -Receive: 113
« Reply #13 on: May 09, 2010, 10:47:39 pm »
what is a qd, is it a quick detail
Offline B3n
  • -Receive: 29
  • Boom!!!!
« Reply #14 on: May 09, 2010, 10:51:26 pm »
Quick Detail spray mate it just gives the car a little top up of protection and adds a little shine inbetween waxing :happy2:
Im currently using red mist
http://www.cleanyourcar.co.uk/wax/dodo-juice/dodo-juice-red-mist-250ml/prod_540.html
« Last Edit: May 09, 2010, 10:53:59 pm by B3n »
