Author Topic: Help with arm rest part no's  (Read 5062 times)
Offline Lee01
« on: May 10, 2010, 11:34:02 am »
Hi All,
I know this has been covered on numerous occassions and I am sure I have seen it covered somewhere however using the search function I am not able to find it again.
Basically I want to add a front centre arm rest, and would be very grateful if anyone could help with the part numbers required including the additional air ducting.
Would also like to add as a newbie,-top site and fantasic community!!  :happy2:
Lee
« Last Edit: May 10, 2010, 12:38:59 pm by Lee01 »
Offline Moschops
  • -Given: 118
  • Edition 30 No 2275
Re: Help with arm rest part no's
« Reply #1 on: May 10, 2010, 01:18:59 pm »
Here's a start fella.
http://www.mk5golfgti.co.uk/forum/index.php/topic,13955.0.html
Some parts numbers on here for you.
Ones not listed are the actual Arm Rest, Main Support Bracket, Air Duct for non CD Changer car and Plastic Housing (again non CD Changer)
Cheers,
Wayne
Offline Lee01
« Reply #2 on: May 10, 2010, 04:07:31 pm »
Moschops,
Thanks for your help.
I have just spent 35 minutes on the phone to my local dealer trying to ascertain the part numbers and was eventually told VW do a retro fit kit, Part Number 1KO 061 124 71 N £220.00 + Vat and I need the air ducting pipe 1KO 864 255 C £12.33 + Vat.
Would anyone know if this sounds right?
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #3 on: May 10, 2010, 05:01:04 pm »
Hi Lee that sounds about right, for both the retro-fit kit and pipping, cant confirm the part numbers, also worth making sure you get the right top either fabric or leather.  you should be able to see what the kit looks like via a quick ebay search, as there is one on there for £220.
Offline Lee01
« Reply #4 on: May 10, 2010, 07:14:38 pm »
Hi Rich,
I'll be sure to check this out.
Lee
Offline Moschops
  • -Given: 118
« Reply #5 on: May 10, 2010, 07:21:26 pm »
Moschops,
Lee,
Which air duct is it you want? CD changer one or none changer one?  If it's the none changer one I have one you can have if you want to pay the p&p...or if your local to Telford or Dudley we can sort something out. Not mint as it's used.  :happy2:
Oh and welcome to the forum.... :driver:
Cheers,
Wayne
Offline Lee01
« Reply #6 on: May 14, 2010, 08:46:19 pm »
Hi All,
Picked up the retofit arm rest kit today, guess what the wrong top, it's a kind of leather effect. However it matches the colour of my interior.
My local parts department are useless, they are telling me they can not find another part number to distinguish between the material and leather top??
As its a retrofit kit I wonder if they only do it with the leather top?
So I then thought perhaps I buy just the top seperate, they quoted me £178 for the top section in material to match the interior of my car.
Can someone help..................please?
Can the top part be removed from the frame / housing?
« Last Edit: May 14, 2010, 08:48:27 pm by Lee01 »
Offline Moschops
  • -Given: 118
« Reply #7 on: May 14, 2010, 09:01:51 pm »
Lee,
It should unscrew from the housing/frame, haven't got my car at work tonight so cannot go and check... :chicken:
Which dealers parts depot are you using?
Cheers,
Wayne
Offline Lee01
« Reply #8 on: May 14, 2010, 09:32:57 pm »
Hi Wayne,
Thanks for your help buddy.
I am using Wayside Volkswagen in Milton Keynes and have also tried Vindis in Bedford but they are no help.
I even searched Autotrader to find another Gti with the same interior so they search that registration number and try to locate the 'Top' to match my interior / fabric.
It's so annoying - You would think these guys should know what they are doing after all it is their job!!
Offline Moschops
  • -Given: 118
« Reply #9 on: May 14, 2010, 09:34:55 pm »
Hi Wayne,
PM SteveP, he uses a dealer near to you and they are helpfull, check out the Wanted section too as there is an arm reset being offered with leather... :happy2:
Cheers,
Wayne
cameluk
« Reply #10 on: May 14, 2010, 09:37:18 pm »
The cover is available on its own, cost varies between £33 for cloth and £67 for leather or leatherette
1K0 864 245 B with colour code options on the end depending on material and colour
Offline Lee01
« Reply #11 on: May 14, 2010, 09:40:05 pm »
Cheers Wayne !
I will do that. Again thanks for your help.
Lee
Offline Lee01
« Reply #12 on: May 15, 2010, 07:53:47 am »
CAMELUK,
Thank you I will, yet again try my luck with the dealer!!
Offline Lee01
« Reply #13 on: May 15, 2010, 07:57:48 am »
Lee,
Wayne,
I have taken another look at my new arm rest. I can seen two small screws on the under side of the arm rest if I extent  the top part forward and lift it up.
I have tried removing them but still can not work out work how  to remove it.
I am reluctant to fit it until I know I can swap the top part easily , i.e. without having to remove the whole thing again!
Any ideas?
cameluk
« Reply #14 on: May 17, 2010, 01:08:07 am »
It certainly comes apart
Unable to find any details on how to separate the two parts
« Last Edit: May 17, 2010, 01:11:19 am by cameluk »
