Author Topic: Help with arm rest part no's  (Read 5058 times)
Offline Moschops
  • -Given: 118
  • Edition 30 No 2275
Re: Help with arm rest part no's
« Reply #15 on: May 17, 2010, 02:59:59 am »
Lee....^^^^^
Thanks to Mr Camel once again... :happy2:
I will try and post up some of my CD install pics ...fecking nightmare.....and still the R to do.. :stupid:
Cheers,
Wayne
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #16 on: May 17, 2010, 09:15:11 am »
Lee, I have the alternative problem to you my dealer could only find one with a cloth top not the leather one.  So I have been searching for a leather top, do you fancy doing a swap cloth for leather then we only have to each pay postage?
PM me if your interested, im based Southeast london if that will help with a swap?
Offline Lee01
« Reply #17 on: May 17, 2010, 11:14:21 am »
Lee....^^^^^
I second that  :happy2:
Offline Lee01
« Reply #19 on: May 17, 2010, 09:02:17 pm »
Theres a good guide to install here
http://translate.google.co.uk/translate?hl=en&sl=da&u=http://vwfanatic.dk/Tips/G5Armlaen.html&sa=X&oi=translate&resnum=1&ct=result&prev=/search%3Fq%3D1K0%2B863%2B323A%2B71N%26hl%3Den%26rlz%3D1G1GGLQ_ENUK276%26sa%3DG%26pwst%3D1
I followed it and the only nightmare was fitting the air duct
Bloody brilliant, - thanks for link.
I eventually fitted it on yesterday, OMG how fiddley? I ended up removing the rear air vent ducting from the new arm rest frame, when I purchased the kit I was advised to purchase another ducting pipe which turned out to be the wrong one, I need the one which split's into two and runs around the gear lever.
So another GTi with decorative rear air vents!!!
Oh and a GTi driver with grazed knuckles!
Offline Moschops
  • -Given: 118
« Reply #20 on: May 17, 2010, 10:20:32 pm »
Lee,
If you can hang on thill tomorrow, I will post up some pics of my install which Greenous and Stevep helped with. I don't think you need to change the other duct. But just the one under the CD Changer.
I will ty and get them up first thing tomorrow morning.  :happy2:
Cheers,
Wayne
Offline Moschops
  • -Given: 118
« Reply #21 on: May 18, 2010, 12:21:11 pm »
Lee
Here you go.
The Arm Rest assembly housing has been removed, what a ballache this was.
View from the back looking forward
The heating/Air con vent is visble bottom left of the centre console on front of the hand brake.
Centre arm rest assembly
The air duct needs to inserted inside here before you put it all back together again as otherwise you will not get the airduct into the assembly once it's back in the car.
Air ducts, non CD player and CD player versions.
The Arm Rest CD player version is the thinner one on the left.
The two versions of the Arm rest console.
« Last Edit: May 18, 2010, 12:30:28 pm by Moschops »
Cheers,
Wayne
Offline Yellow
« Reply #22 on: May 18, 2010, 08:32:19 pm »
No need to remove the screws, on the underside of the leather/cloth top pull on the plastic cover from the hinged edge, it will pop off. Then its a case of easing the cover off the arm, again start at one end and it will pop off.
Offline animal
  • .:R32
« Reply #23 on: May 18, 2010, 11:00:26 pm »
Do all the CD changer armrests have the cut-out at the front for the 3.5mm Aux-In?
Offline Moschops
  • -Given: 118
« Reply #24 on: May 18, 2010, 11:28:15 pm »
No, I wanted the cut out as I have the Aux socket in my old arm rest.
Cheers,
Wayne
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #25 on: May 19, 2010, 08:56:14 am »
Any chance you could confirm the part number on the underside of that leather arm rest for me yellow?  The photo is a bit blurry, I have a cloth top on mine with leather interior, garage I bought it from failed on numerous occasions to find the correct part!
Offline Yellow
« Reply #26 on: May 20, 2010, 10:42:04 am »
1K0 864 245B       4136 for the leather
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #27 on: May 20, 2010, 10:48:37 am »
Cheers Yellow   :drinking:
