Author Topic: Cruise again  (Read 2787 times)
Offline liver
Cruise again
« on: May 10, 2010, 03:29:55 pm »
i have searched and im still confused lol
what is the best way to find out if you need the control module and the cruise wire?
i have a 55plate 06 model with no mfsw or highline but have retro fitted rns510 with no problems.
any help as to finding out is much appreciated
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: Cruise again
« Reply #1 on: May 10, 2010, 06:07:06 pm »
There are some part numbers which are known to be working with CC.
55 plate would be on the cusp of a change but if yours is a 2006 you should be ok for the wire.
If I were you I'd fit it and see how you get on, I think most GTi's are ok.
Stu...
Offline liver
Re: Cruise again
« Reply #2 on: May 10, 2010, 10:00:32 pm »
thank you for the information
much appreciated, i will get on the look out  :drinking:
Offline liver
Re: Cruise again
« Reply #3 on: May 11, 2010, 10:20:00 am »
is there a tutorial for fitting
for some reason vortex isnt working for me at all
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: Cruise again
« Reply #4 on: May 11, 2010, 10:25:10 am »
Not that I'm aware of but plenty of help here.
Stu...
Offline liver
Re: Cruise again
« Reply #5 on: May 11, 2010, 10:26:45 am »
i did a search but couldnt find one either,
there is one on vortex but the link doesnt work atm none of them do for myself just goes to an unspecified link page.
got the chance for a stalk at £30, if it doesnt need the wire etc after fitting will it just need coding? whats the going rate?
Offline Richn83
  • -Given: 49
  • -Receive: 85
Re: Cruise again
« Reply #6 on: May 11, 2010, 10:29:50 am »
check the VCDS register run by VRSTU and see if there is someone local to you, then offer them a beer  :party:
Offline liver
Re: Cruise again
« Reply #7 on: May 12, 2010, 08:54:34 am »
picked up my cruise stalk last night, got some one to code it for me, now just need to find out how to fit it.
Are there any guides or what did people use to fit there own???
any help is much appreciated
Offline liver
Re: Cruise again
« Reply #8 on: May 12, 2010, 11:48:41 am »
could i follow this guide to fit and just add in taking stalk out and back in??
or does the steering wheel not need to come off??
http://forums.vwvortex.com/showthread.php?2938601
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: Cruise again
« Reply #9 on: May 12, 2010, 01:04:07 pm »
That's for sure not the way to get the control module off!!  Follow his advice from the Bentley and use the correct tools, it's actually quite easy.
Stu...
Offline liver
Re: Cruise again
« Reply #10 on: May 12, 2010, 01:18:39 pm »
i only need to change the stalk thats all hopefully so i should be ok following the guide??
the wheels coming off then yeah??
there is a link on vortex for this retro fit but it doesnt work v.gay
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: Cruise again
« Reply #11 on: May 12, 2010, 01:48:53 pm »
You still have to take the controller off.
Stu...
Offline liver
Re: Cruise again
« Reply #12 on: May 12, 2010, 01:52:46 pm »
ohh right
might get help fitting this then as there is no out and out guide lol
Offline liver
Re: Cruise again
« Reply #13 on: May 12, 2010, 04:17:07 pm »
this is what i have atm
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: Cruise again
« Reply #14 on: May 12, 2010, 04:34:11 pm »
The guide you linked to will get you most of the way.  I can't see your picture as the fun police at work have blocked it.
Stu...
