Author Topic: Belly plate  (Read 2254 times)
Offline chip20
  • -Given: 35
    • http://absolutevaletinguk.co.uk/
Belly plate
« on: May 11, 2010, 10:31:02 pm »
Hi.Just a quick question.Do ED30's have a belly plate? Had mine in at stealers the other week then took it to my mates garage to make sure all was in order underneath and noticed no belly plate! Can somebody shed some light on the issue?
Re: Belly plate
« Reply #1 on: May 11, 2010, 10:34:02 pm »
Yes it should have one!
So either it's fallen off because the dealer didn't screw it back correctly or they forgot to put it back on.
Re: Belly plate
« Reply #2 on: May 11, 2010, 10:42:49 pm »
Did you let Joes GTi near your car, he has a habit of leaving these on slip roads.  :evilgrin:
Offline chip20
  • -Given: 35
Re: Belly plate
« Reply #3 on: May 12, 2010, 10:17:12 am »
Hi.Thanks for your help.Spoke to stealers this morning.
They have said it's only a small plate at the front!
Is this correct?
Re: Belly plate
« Reply #4 on: May 12, 2010, 10:37:49 am »
Is this correct?
The belly pan aka the undertray isn't what I describe as a small piece of plastic.
Here is a pic of about half of it. There are four more bolts holding it in place on the other side.
If not fully bolted in it tends to fall off after a while. Now where is Joe...   :laugh:
Offline chip20
  • -Given: 35
Re: Belly plate
« Reply #5 on: May 12, 2010, 11:00:05 am »
Thanks mate.looks like the one I have on! Panic over!
I take it Joe is not the man to fit the undertray then!
Re: Belly plate
« Reply #6 on: May 12, 2010, 01:05:46 pm »
I'll leave Joe to answer that one...   :smiley:
