Author Topic: Strange misfire issue when cold  (Read 3232 times)
Offline DanGB
  • Different
« on: May 13, 2010, 10:01:08 pm »
Hello Chaps!  :smiley:
Have a APR stage 3 car, Been having an issue, it appeared last year for a while, but went away, and now its appeared again for the last few months.
Basically, when the car is completely cold ie; when going to work in the morning, (not going home from work in the evening) it misfires on most or all cylinders on low revs until the car has reached 90c or just after that.
It doesnt bring up a CEL or Fault code, but can see it happening with VAG-COM on each cylinder, and can certainly feel it stuttering alot of the time.
Ive changed all coils and plugs, no difference. Intake flap motor was changed by my tuner a year ago.
APR have basically said go to VW[SEAT] and get them to fix it, but thats not an option because its out of warranty and they'd just blame all the modifications as per usual.
Im at a bit of a loss with this what to do now. Would be grateful for suggestions or help.
Seat Leon Mk2 TFSI sport 4WD sleeper - Breaking
Buld thread: http://www.mk5golfgti.co.uk/forum/index.php/topic,45377.0.html
Re: Strange misfire issue when cold
« Reply #1 on: May 13, 2010, 10:07:24 pm »
This may be of some help even though you don't have a stored fault code
Technical Service Bulletin Transaction No.: 2017063/2
01-08-04 - MIL ON, Misfire DTC P0301, P0302, P0303 or P0304 Stored in ECM Fault Memory after Cold Start Release date: Oct 9, 2008
Condition
01 08 04 Jan. 23, 2008 2017063
MIL ON, Misfire DTC P0301, P0302, P0303 or P0304 Stored in ECM fault Memory after Cold Start
At times engine may run slightly rough for a few seconds after cold start. MIL may illuminate with a DTC for misfire on one cylinder only (P0301, P0302, P0303, P0304) stored in the ECM fault memory. Rough running condition disappears a few seconds after cold start and DOES NOT exist with a warm engine.
Technical Background
Not applicable.
Production Solution
Not applicable.
Service
1. Follow normal Guided Fault Finding Diagnosis, for example:
• Swap spark plugs and ignition coils between affected cylinder(s) and good cylinder(s).
• Check compression and leak-down of affected cylinder(s).
• Verify fuel quality. (Also refer to Technical Bulletin 2014815 - Gasoline Quality.)
• Swap fuel injectors between affected cylinder(s) and good cylinder(s).
Note:
When swapping fuel injectors, always replace all fuel injector seals.
2. If diagnosis results are inconclusive, and above mentioned condition persists, replace all 8 Hydraulic lash adjuster (lifters) of affected exhaust side.
Warranty
Information Only.
Required Parts and Tools
For Part No. reference, see table below:
Part Number
Part Description
Quantity
022 109 423 D
8 (if needed)
06F 103 483 D
Valve Cover Gasket
1 (if needed)
06D 998 907
Sealing Kit for Fuel Injectors
1 (if needed)
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #2 on: May 13, 2010, 10:41:55 pm »
the VAG's strike again aye?
No use taking it to SEAT mate cause they wont have a clue, they cant even fix things when theres tons of fault codes all relating to the same thing  :scared:
Could try APS, or our local audi dealer though.
Best of luck, PS the noise seems to have disappeared from my car.
Offline DanGB
  • Different
« Reply #3 on: May 14, 2010, 09:01:52 am »
Thanks Bacillus, I dont think its that, but will look into that further.
Who do you mean by APS Jase?
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #4 on: May 14, 2010, 12:33:27 pm »
does it do it in stock mode Dan?
Red ED35 5dr DSG
BLOG | BUILD
Offline DanGB
  • Different
« Reply #5 on: May 14, 2010, 12:51:43 pm »
Will try that john! (bearing in mind Stage 3 is the big turbo kit etc)
