Author Topic: H&R ARBs Adjustable fitting?  (Read 5842 times)
Offline geordie56
« on: May 13, 2010, 10:04:07 pm »
Hi, i am getting the H&R arbs and just want to know the holes nearer to the outside or nearer to the inside which makes it stiffer? And is it the same for both the front and the rear? Cheers.
Offline Janner_Sy
  • -Receive: 113
Re: H&R ARBs Adjustable fitting?
« Reply #1 on: May 13, 2010, 10:05:06 pm »
inner holes are stiffer ones.   its like using a lever, the longer it is the easier to lift or bend
Offline gazbutS3
« Reply #2 on: May 13, 2010, 10:05:36 pm »
the  hole at the end of the bar is the softer setting F&R :smiley:
« Reply #3 on: May 13, 2010, 10:06:15 pm »
I would like to know the same thing! Im literally in the middle of fitting these myself. Mine were a second hand set and I could clearly see the ones previously used were the ones closest the end
Offline geordie56
« Reply #4 on: May 13, 2010, 10:13:07 pm »
Spot on cheers for your help guys!
Offline Teutonic_Tamer
  • -Given: 88
  • -Receive: 95
« Reply #5 on: May 14, 2010, 06:17:26 pm »
You're all wrong.  The bolt hole which is the FURTHEST away from the pivot is the 'stiffest' setting.  Search for the Whiteline adjustable ARB pdfs . . . .
« Reply #6 on: May 14, 2010, 07:19:56 pm »
Balls!!
Offline Janner_Sy
  • -Receive: 113
« Reply #7 on: May 14, 2010, 07:28:51 pm »
i spke to eibach before adjusting mine and they said the opposite to you.  anyone go the link to the whitleine pdf, i cant be arsed searching lol
  • -Given: 88
  • -Receive: 95
« Reply #8 on: May 14, 2010, 07:49:28 pm »
Think about the length of lever needed to undo f-ing tight wheel bolts.  With a short 12" bar, you probably won't be able to undo them - but with a 30" breaker bar, they will be easy.
At the end of the day - they are ANTI-roll bars, and use a simple 'lever principle' to counteract differential torque (twisting force) along the length of the ARB.  So the bolt hole closest to the centre-line of the ARB will be less able to cope with the torque than the bolt hole furthest away.
www.whiteline.com.au/vehicle_swaybars.php is a starter for 10.
Offline Janner_Sy
  • -Receive: 113
« Reply #9 on: May 14, 2010, 07:58:45 pm »
that to me backs up what myself and everyone else have said  by using the inner hole, you have less 'leverage' from the bolt to the centre line so it will roll less as its harder to bend.
If you use theouter hole the 'lever' is longer so it would 'bend so to speak' easier and thus roll more.
I stand to be corrected, no one is right all the time,  but the above makes sense to me, eibach also confirmed it as have others.  ill have a look through the PDF after i pick the wife up from work
« Reply #10 on: May 14, 2010, 08:00:41 pm »
I'm still thinking the inner hole will make things tighter. :s
Offline gazbutS3
« Reply #11 on: May 14, 2010, 08:37:33 pm »
thatst the way I saw it, the outer hole gives a larger lever so can bend the bar so give some roll, inner hole less leverage can't bend the bar so less roll :smiley:
 could be wrong but I did ask quite a few people, one with vast racing experience :wink:, and was told by everyone the outer hole is softest setting
Offline jabbalad
    • Jabbasport
« Reply #12 on: May 14, 2010, 08:55:07 pm »
the further out the hole is the less of an effect the arb has!
So like others have said the inner hole is the stiffer setting!
(i could be wrong but that would mean all the setup work on race cars and running my own race cars for the last god knows how many years has been completely wrong!)  :happy2:
12.7 santapod... soon to be quicker :-)
Candy White Edition 30; Custom KW clubsports, Eibach hollow arbs, Jabba remap, BTB Exhaust, Twintake, Autotech HPFP, Team Dynamics wheels, VWR Big Brakes.
Offline gazbutS3
« Reply #13 on: May 15, 2010, 12:45:40 pm »
BUMP,
I'd like to know the outcome of this discussion :smiley:, so we know if we have our ARB's set where we think we have them :happy2:
  • -Given: 88
  • -Receive: 95
« Reply #14 on: May 15, 2010, 01:03:22 pm »
Anti-roll bars work on counteracting torque reaction.  IE, they are 'reactive' rather than 'proactive' - so you need to reverse your logic.  If you have 'less leverage', then you simply have a less efficient, therefore less hard anti-roll bar.
I can't scan my Whiteline docs (dead desktop puter), but they clearly state that the OUTER holes are for the hardest (ie stiffest) setting.
