Author Topic: Bl**dy rear wiper!  (Read 5930 times)
Offline Tuffy
Bl**dy rear wiper!
« on: May 15, 2010, 01:58:52 pm »
Hi all.
Trying to change my boot latch over for a new one as old was suffering from white worm.
Now managed to get boot lining out to expose all the nuts a screws i need to remove but doesn't matter what i try i cant remove the rear wiper arm to inable the motor drop out! Wd40, pulled it twisted it and still wont move!!!
You guys had trouble with this? Any ideas?
Thanks in advance guys.
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
Re: Bl**dy rear wiper!
« Reply #1 on: May 15, 2010, 02:04:49 pm »
The best way I have found is (after using some WD40 on the nut), wrap a soft cloth around the shaft and using a large headed spanner (adjustable ones work well) try to prise the wiper arm off. Then if the motor still won't drop out use a rubber mallet to tap it through.
However IIRC by loosing the wiper motor you can normally get to enough of the screws to remove the boot badge.
Offline Sparky Craig
  • Looking To Sell my R32 :(
    • My R32 Page
« Reply #2 on: May 15, 2010, 02:04:49 pm »
Yeah it is hard but just need a LOT of pushing and pulling.... then it WILL come off :)
Offline Tuffy
« Reply #3 on: May 15, 2010, 02:10:57 pm »
I've pulled so hard nearly pulled the glass out of the rubbers!  :signLOL:
Offline Tuffy
« Reply #4 on: May 15, 2010, 02:13:00 pm »
Tried the mallet trick too! still wont shift!
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #5 on: May 15, 2010, 02:14:21 pm »
Which bit is stuck?
Have you got the wiper arm off?
Offline Tuffy
« Reply #6 on: May 15, 2010, 02:18:06 pm »
Which bit is stuck?
No wiper arm still on! took the nut off thinking it would just pull off but not a chance!!!
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #7 on: May 15, 2010, 02:20:20 pm »
You just need to be braver with the mallet.
I have removed around 10 of these on different cars now for the rear camera install and they all required a lot of force.
I still find it easier to prise the wiper arm off with the adjustable spanner and the use the mallet to knock the motor through.
Offline ollie288
« Reply #8 on: May 15, 2010, 02:26:11 pm »
I also used this method. Takes a lot of force to do, but you will get it off in the end.  :happy2:
Offline Tuffy
« Reply #9 on: May 15, 2010, 03:02:47 pm »
DONE!!!!! Only problem being is i've broken the small piece that pushes in the end of the wiper motor shaft that directs the water on to the screen (only push on part)  :ashamed: Is this a seperate part i can buy or do i need to look for a knackerd motor an take it off?
Thanks for all your help Guys.
Offline Matt23
« Reply #10 on: May 15, 2010, 06:14:10 pm »
You can buy the part as i have replaced mine as it was broken when i got the car. It was about £5 don't know the part number though.  :happy2:
Offline Tuffy
« Reply #11 on: May 15, 2010, 07:29:56 pm »
Nice one matt!
The part is about 5mm long with the metal ball in the end to direct the water. That right????
    • My R32 Page
« Reply #12 on: May 15, 2010, 07:45:19 pm »
Be gentle as this ETKA is new to me but I THINK the part number MAY be 3B9 955 985 A  - Spray Jet
Hopefully someone else with more experience with ETKA will either confirm the number or give you the right 1   :happy2:
« Reply #13 on: May 15, 2010, 08:24:01 pm »
Wish I'd seen this earlier :ashamed:
There's no need to remover the arm. All you needed to do to get the handle out was to unscrew the wiper motor and rotate it through 90 degrees and you can get the handle unit out whilst still keeping the motor and wiper arm in tact.
Offline G30 MC
« Reply #14 on: May 15, 2010, 09:12:24 pm »
Mines was a total nightmare to come off :rolleye: i ended up cutting {VERY CAREFULLY} the nut off. Everything still intact :happy2:
