Author Topic: Bl**dy rear wiper!  (Read 5934 times)
Offline Matt23
Re: Bl**dy rear wiper!
« Reply #15 on: May 15, 2010, 09:29:27 pm »
Nice one matt!
The part is about 5mm long with the metal ball in the end to direct the water. That right????
[/quote]
Yeah thats the bit a replaced.
Offline Tuffy
« Reply #16 on: May 16, 2010, 09:39:59 am »
Wish I'd seen this earlier :ashamed:
There's no need to remover the arm. All you needed to do to get the handle out was to unscrew the wiper motor and rotate it through 90 degrees and you can get the handle unit out whilst still keeping the motor and wiper arm in tact.
Oh well no worries. It may help someone else out on here Hurdy.
Offline Tuffy
« Reply #17 on: May 16, 2010, 09:42:40 am »
Mines was a total nightmare to come off :rolleye: i ended up cutting {VERY CAREFULLY} the nut off. Everything still intact :happy2:
It wasn't the nut that was the problem, that came off fine! it was actually pulling the arm off the shaft to let the motor to drop
Offline Tuffy
« Reply #18 on: May 16, 2010, 09:44:29 am »
Be gentle as this ETKA is new to me but I THINK the part number MAY be 3B9 955 985 A  - Spray Jet
Hopefully someone else with more experience with ETKA will either confirm the number or give you the right 1   :happy2:
Your always there for me Craig!!  :grin:
Offline ashley
« Reply #19 on: May 16, 2010, 11:01:44 am »
Just dewipered the rear. On my last mk5 I had a similar issue.
Purchased a wiper arm removal tool. Cost £10 just saved any hassled or risk of damage. Mines Sykes Pickavant but laser do one the same.
Search a well known auction site for "wiper tool".
