Author Topic: Heeeeelp pls. Monza Valves Don't fit!!!!!  (Read 9611 times)
Re: Heeeeelp pls. Monza Valves Don't fit!!!!!
« Reply #30 on: May 24, 2011, 03:43:14 pm »
fwiw I have changed two sets of tyres and left the original valves in place...   :smiley:
Offline winrya
« Reply #31 on: May 24, 2011, 06:00:46 pm »
I've had the same ones In place for almost 6 years!
Offline manc01
« Reply #32 on: May 24, 2011, 09:15:34 pm »
OK that sounds betta. thanks all. S'pose main thing is to let the tyre fitters know so they dont throw it.! Maybe i should able to save a bit as most of them charge a bit more for valves.. :happy2:
« Reply #33 on: May 24, 2011, 09:35:01 pm »
My fitter didn't want to even touch my metal valves...   :scared:
MPS
« Reply #34 on: February 05, 2018, 05:48:17 pm »
Sorry for the thread resurrection but I've had my wheels refurb'd to try and cure leaks and it's made them even worse!  :grin: :congrats:
The o-ring as mentioned earlier in this thread has conflicting advice, the elsawin diagram tends to suggest the o-ring [#5 on the diagram, link below]  is fitted on the inside of the wheel but another chap on this thread says that that is wrong and it should go on the outside, as the metal stem [#6] already has a rubber seal bonded to it. [Which sounds like it makes sense]. But I'm beginning to think that the elsawin diagram is actually correct as my wheels have come back with o-ring fitted outside and the pressure loss is much greater. It's counter-intuitive to say the least! So, this is where you chaps/ladies with hollow type BBS Monza 2's come in, could you all have a look and tell me if your orange o-ring [oo-er] is visible between the metal washer and the body of the wheel itself? @RedRobin  I believe you have Monza 2s of the type I'm on about?
http://workshop-manuals.com/volkswagen/golf-mk5/running_gear_axles_steering/wheels_tyres._axle_align/wheels_tyres/alloy_wheels_with_metal_valves/
TIA,
MPS  :happy2:
« Last Edit: February 05, 2018, 05:54:18 pm by MPS »
Offline Octoparrot
  • -Receive: 102
« Reply #35 on: February 05, 2018, 06:39:28 pm »
When I recently dismantled the valves on mine there wasn't an o ring in the inside of the wheel just the seal that seems to be part of the stem. The outside part that screws onto it had a seal at the bottom of it which again seemed to be part of it so that the wheel is sandwiched between two rubber seals. There definitely wasn't a loose o ring, just the seals that seemed to be part of the assembly. I can't see why there'd need to be an extra o ring.
« Reply #36 on: February 05, 2018, 07:37:33 pm »
....I have been riding on OZ Aleggerita alloys for 8 years and don't remember anything about the valves, especially as ATS did and still do all my tyre fitting. Sorry I can't help.
MPS
« Reply #37 on: February 05, 2018, 08:35:02 pm »
No worries, cheers.
Offline nc35
  • -Given: 40
« Reply #38 on: February 05, 2018, 10:37:22 pm »
I can confirm the esta diagram is correct.
Brings back memories lol...
Sent from my SM-T585 using Tapatalk
No Golf anymore.
Enjoyed the last five years of ownership of Mk5 & 6 GTIs.
Plus an excellent forum for knowledge and new ways to deplete the bank account.
Thank You Everyone.
MPS
« Reply #39 on: February 05, 2018, 10:50:38 pm »
So the o-ring does sit on the inside of the wheel?
MPS
« Reply #40 on: February 06, 2018, 04:27:26 pm »
Offline coolhandluke
  • -Given: 28
« Reply #41 on: February 06, 2018, 04:40:02 pm »
Is it possible to replace just the O ring or is it an integral part of the valve ?
I've reused mine even after a wheel refrub but guess they won't last forever.
