Author Topic: ED30 - K04 hybrid!  (Read 31693 times)
Re: ED30 - K04 hybrid!
« Reply #15 on: June 05, 2010, 08:37:29 pm »
Update,
Confirmed via VCDS.
303gms/sec at 7350rpm from the K04 hybrid. :innocent:
Still not fully tuned either. :rolleye:
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #16 on: June 05, 2010, 08:39:41 pm »
That works about at about 378bhp.
Isn't that less than you had before?
Or does this hold that power for longer?
« Reply #17 on: June 05, 2010, 08:49:29 pm »
Side by side the K04 hybrid is definitely faster up top.
ITG intakes are pulling in around 280gm/sec. Similar to Evoms and Twintakes.
Not my Hybrid BTW :smiley:
Oh and it is running GIAC software.
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #18 on: June 05, 2010, 08:52:35 pm »
So do you reckon you could break the 400bhp mark if you put one on yours?
Offline Janner_Sy
  • -Receive: 113
« Reply #19 on: June 05, 2010, 09:19:52 pm »
stadtler being playing with hybrids then have they.  this looks to me like you are about to fettle wit your turbo :wink:
was that with an ITG??
more importantly rather than just looking at that peak figure, what was the original g/s prior to the hybrid.  be good to see the gains
« Last Edit: June 05, 2010, 09:21:50 pm by vRSy »
« Reply #20 on: June 05, 2010, 09:32:01 pm »
Who says I haven't :wink:
Nail on head :grin:
They use a VF intake.
You are looking at a good 20-30g/s increase, but I haven't seen the full logs graphed yet.
My Guesstimation (is that a word?) is that the air intake will pass the stock K04 around 3.5krpm and gain ground to the redline and still making power at the redline (7400rpm).
I'm also hoping that the g/s will increase when the mapping is completed. At the moment he is running a GIAC K04 race file.
Offline Janner_Sy
  • -Receive: 113
« Reply #21 on: June 05, 2010, 09:38:10 pm »
you reckon you could get them to  post them up on here :happy2:  im sure alot of guys would be intersted in that.
good news for jabaluke. this means the GIAC dsg remap hasno issues, so he could bin of his revo DSg jobbie.
« Reply #22 on: June 05, 2010, 09:43:39 pm »
Never thought of that, but you are right. Steve has no issues with his car at all. :happy2:
Craig is already a member on here, but neither of them really get time out of running the business as they work 8am till 9pm most days.
I'll get hold of the logs next week and graph them to do a direct comparison if they are okay with it :happy2:
« Reply #23 on: June 05, 2010, 10:25:54 pm »
Me. Prove me wrong.  :P
« Reply #24 on: June 05, 2010, 11:03:05 pm »
I drew this earlier :signLOL:
Offline micky 32
« Reply #25 on: June 06, 2010, 12:06:52 am »
What does the standard KO4 (mg) run at the redline? What gear to use 4th?
2008 Octavia vRS K04'd , Forge twintercooler, Evoms, Autotech uprated pump, full Milltek exhaust 324bhp on JKM's rollers ;-)
« Reply #26 on: June 06, 2010, 12:26:36 am »
Technically you can use any gear but you may be limited by the sampling rate in vcds in first and second gear. There is adequate sampling rate in third gear upwards
« Reply #27 on: June 06, 2010, 03:51:04 am »
Mine ran 194g/s max (but drops off at redline)
I always run 3rd or 4th gears and ask for 4th for a dyno. :smiley:
Offline Janner_Sy
  • -Receive: 113
« Reply #28 on: June 08, 2010, 10:17:44 pm »
any more info then.
have you spoken to revo about using their k04 stage 2+ software on the hybrid
« Reply #29 on: June 08, 2010, 10:41:52 pm »
I suspect the standard revo map even with sps plus tweaking won't be able to fully handle the hybrid boost profile.
