Author Topic: A Few problems today, help appreciated - oil usage - washer leak  (Read 6102 times)
Offline gobbleplease
  • -Given: 64
  • -Receive: 48
Well today i checked the oil level for the first time since i bought the car 6 months ago and it was sitting very low (in line with he minium level), so i went to halfords and bought some castrol edge, fully synthetic, long life, 5-30 oil and the car took about 1 liter and this is only with me using the car for around 2000 miles (short distances) mainly.
I find this quite worrying that the car uses this much oil as ive had some bangers in my time and ive never needed to top up oil before :scared: Is this a common characteristic of the gti or should i be worried. Also have i bought the correct oil, it said for Vag engines on the bottle and had vag standards on the lable 502 504 505 i think ?
Another problem is i went to fill up the washers today and it basically spat out he water i put in to it ! i was wondering if it is a bumber off job too get in to the washer tank and check for leaks at the hose connections ect, or if there was an easyer way to gain access
TA guys  :happy2:
MK7 GTI - ARRIVING DECEMBER
Offline Russ_leeds
Re: A Few problems today, help appreciated - oil usage - washer leak
« Reply #1 on: May 21, 2010, 06:04:58 pm »
dont know about the washers mate, but i had to top my oil up the other day, and i too have only owned the car about 6 months :sad1:
Black 2007 gti, 18' monza 2, sat-nav, highline, i-pod dock, armrest, 35mm H&R springs, WALK, BCS tbe, autotech front and rear arbs, ITG maxogen, NQSBBK... and more to come
  • -Given: 64
  • -Receive: 48
« Reply #2 on: May 21, 2010, 06:10:16 pm »
whats your milage bud ?
short journeys too ?
Offline Russ_leeds
« Reply #3 on: May 21, 2010, 06:12:45 pm »
40k mate yeah a few short journeys, mixture really. i dont think keeping the boot down helps :evilgrin:
  • -Given: 64
  • -Receive: 48
« Reply #4 on: May 21, 2010, 06:17:00 pm »
Im 40k aswell, lets hope someone can shed some light on it   :popcornsoda:
Offline ub7rm
  • -Given: 35
  • -Receive: 43
« Reply #5 on: May 21, 2010, 07:29:47 pm »
I've found it a lot thirstier on oil than my old 1.8T.  Seems to be 'normal'.
Sepang Blue S4 BE Avant
  • -Receive: 291
« Reply #6 on: May 21, 2010, 08:37:43 pm »
VW expect 1 litre per 1000 miles to be normal.
  • -Given: 64
  • -Receive: 48
« Reply #7 on: May 21, 2010, 09:40:41 pm »
thanks bud ! is that a statement VW have made ? thats quite alot
Offline winrya
« Reply #8 on: May 21, 2010, 10:18:42 pm »
It is indeed.  Dealers are advised to consider the above as normal, if it consumes anymore they will look into it
« Reply #9 on: May 21, 2010, 10:31:32 pm »
First off have you been on the moon for a couple of years, it is a well known fact that a lot of Mk5 GTI's use lots of oil there must be 20 threads on here discussing it.  :smiley:
And more importantly how can you go 6 months without checking your oil.  :chicken: Even if you didn't know about the Mk5 excessive usage 6 months without a simple dip is not good practise at all fella.  :fighting:
Consider yourself told off.  :fighting2:
And the jets on your wipers may simply be blocked.  :happy2:
Offline keith
« Reply #10 on: May 21, 2010, 10:46:17 pm »
Its longlife III oil, you can use the Quantum stuff as its vag approved. dealer charged me £24 for 1 unit on a recent service robbin gits I bought 5L for £26 the week before to top it up, i was not impressed next time I putting the bottle on the seat for them and save my dosh.
Offline mk2mexico
« Reply #11 on: August 31, 2010, 04:06:17 pm »
yep my 06 gti also uing about 1lt per 1000 miles???
and meyo around filler cap?? :confused:
Offline Pummy
« Reply #12 on: August 31, 2010, 04:09:12 pm »
Mayo does not sound healthy, for both types.
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #13 on: August 31, 2010, 05:13:09 pm »
.......might get a little in the very cold weather but not this time of year?.
Offline Boothy
« Reply #14 on: August 31, 2010, 07:28:34 pm »
How much oil is there between the top and bottom marks on the dip stick? Does that make sense?  :laugh:
Mine uses a fair bit but I'm curious as to how much the oil the car needs to loose before it drops from the top to the bottom mark on the dip stick?
