Author Topic: Squeaking/chirping noise, could be the brakes?  (Read 1597 times)
Offline Nickyboy
  • 2007 ED30 in Grey
« on: May 22, 2010, 09:01:28 pm »
Rear discs have a 2mm lip but pads have around 8mm left, but after i've been driving for a few minutes I hear a squeak/chirp from the car, not constant just about 3 times a second, could be the front or the back. Goes away when I tap the brakes, but when coming to a half there is a constant squeak.
Squeak goes when I turn left and louder when I turn right.
Guess it's the corrosion on the discs?
Offline Nickyboy
  • 2007 ED30 in Grey
Re: Squeaking/chirping noise, could be the brakes?
« Reply #1 on: June 01, 2010, 01:04:12 pm »
Any ideas?
Offline Nickyboy
  • 2007 ED30 in Grey
« Reply #2 on: June 24, 2010, 06:21:03 pm »
Had the front brakes blast cleaned, just like new, problem remains? Garage saying could be wheel bearing?
Offline Teutonic_Tamer
  • -Given: 88
  • -Receive: 95
« Reply #3 on: August 30, 2010, 03:54:15 pm »
How old is the car, how many miles?
It could be a wheel bearing problem, however, I'd be more inclined to strip the rear caliper slides, clean and regrease with some appropriate rubber lubricant (either the genuine OEM stuff - G 052 150 A2, or sommat like Lockheed Rubberlube).
Also, remove discs, thoroughly clean mounting face on hub and inside of disc, apply a thin coat of anti-seize paste (ideally nickel based - but copper will suffice).  Finally, make sure pad back plates and hammer heads are also clean lubed with anti-seize.
Do all that - and your brakes will be quieter than a dead nuns chuff!
Offline N!CK R
« Reply #4 on: January 23, 2011, 02:04:15 pm »
Did you ever find the solution to this problem? I'm sure I have the same problem on mine, seemed to become apparent after I had the tracking done on the car  :confused:
Offline Nickyboy
  • 2007 ED30 in Grey
« Reply #5 on: April 01, 2011, 10:30:27 am »
Went away after a while  :confused:
