Author Topic: Forge twintercooler  (Read 19958 times)
Re: Forge twintercooler
« Reply #15 on: May 25, 2010, 02:38:08 pm »
The cost of the kit you would think the silicon hoses would be specific to that engine.
....Logical and ideal from a customer pov, but you say that without appearing to know that much about the practical economics of relatively small production runs which a manufacturer like Forge or their specialist supplier has to allow for.
Consider all the R&D costs and then the production costs of what is a low volume product designed and built to a high standard using high standard materials and then tell me it's expensive.
I think there are no less than 5 different 2.0T FSI platforms and hence sets of sizes to cater for.
Offline joesgti
  • Eat my sick, Eat my sick.
« Reply #16 on: May 25, 2010, 02:40:28 pm »
It took me and Mat longer to fit that pipe, than it did to fit the S3 cooler and twinter together.  :fighting:
Why didn't you call Joe to help out...    :evilgrin:  :laugh:
ooooooo  :P my cooler is just fine, god knows where those extra bolts went!  :rolleye: :grin:
« Reply #17 on: May 25, 2010, 02:44:08 pm »
that was after i cut some off the buggers  :fighting: i ended up cutting lots off  :rolleye:
« Reply #18 on: May 25, 2010, 02:48:34 pm »
That doesn't look good, Mat - It looks collapsed. :sad1:
« Reply #19 on: May 25, 2010, 02:56:56 pm »
yep it did but after lots of chopping it looked lots better  :rolleye: but as said you should not need to do this as this is a kit for a car that should fit with no messing about  :smiley: for the the IC is great but its the pipes that bring the product down  :smiley:
« Reply #20 on: May 25, 2010, 02:59:12 pm »
True but did he get the correct S3 twintercooler hoses or are those hoses meant for the standard GTI twintercooler?
« Reply #21 on: May 25, 2010, 03:01:07 pm »
yes mate 100% asked for s3 ic hoses and we even asked if thats what they sent and they did
Offline GTIjames
« Reply #22 on: May 25, 2010, 03:05:56 pm »
regal failed miserably when attempting to fit my twintercooler, had to take it to jkm in the end and the pipes still looked a little kinked, but worked well  :happy2:
if you want hard pipes this offering from VF looks the business, but not cheap at c£1000
« Reply #23 on: May 25, 2010, 03:08:03 pm »
I know it's a bit late in the day but can you remember if the hoses were numbered 296 and 297? Those are the numbers on the S3 hoses.
« Reply #24 on: May 25, 2010, 03:10:01 pm »
no idea on numbers and that VF kit looks more like it as it uses the oe fixings
Offline CarrG
« Reply #25 on: May 25, 2010, 03:34:04 pm »
Come on I understand economies of scale.
We are talking hoses here not cores how much R&D is required?
And as you say there are not that many platforms.
K1 Revo 2+
Ibis RS3
Offline GTIjames
« Reply #26 on: May 25, 2010, 05:10:13 pm »
if you have a kink in the pipework this is what forge recommend...
Offline owen lcr
  • owen
« Reply #27 on: May 25, 2010, 05:45:19 pm »
I think it looks like agood bit of kit aswell but agree that it could be better with specific cut hoses.
If i were to fit a twintercooler to my leon cupra   (that has S3 cooler installed already) what setup would i need?
i.e. Cupra twintercooler with S3 hoses and couplings or am i totally wrong,  i know its a golf forum but no-one on seat had fitted a twintercooler to an S3 intercooler yet
thanks
« Reply #28 on: May 25, 2010, 06:04:38 pm »
....Your post emphasised the cost of the whole kit, not just hoses - Hence my response.
And no, I'm saying that 5 platforms is quite a lot.
Offline RobH
  • Revo stg 2+
« Reply #29 on: May 25, 2010, 06:14:09 pm »
Other companies have managed to get the hoses the right lenght i mean it carnt be that hard you just measure the lenght required on the 5 different varients and cut them :confused:
If they've done sooooo much R&D then they'd know the lenghts anyway.
Not disputing it been a good product because it is but its just cutting a bit of silicone and for £500 youd expect that to be done.
