Author Topic: Turbo Whistle... Possible Fault??  (Read 16045 times)
Offline gazbutS3
Re: Turbo Whistle... Possible Fault??
« Reply #15 on: May 26, 2010, 09:09:13 pm »
Its the diverter valve, basically does what a dump valve does, releases boost preesure on closed throttle :smiley:
Offline shamrock
« Reply #16 on: May 26, 2010, 09:13:12 pm »
My s3 whistles in fifth gear only at a specific rpm.  Is this that noise?
Offline Pullafacial
« Reply #17 on: May 27, 2010, 08:58:38 am »
Don't think so shamrock. All seems fine driving at constant speed.
Problem is when I floor it, it picks up strong for a split second then the turbo whistle turns in to a noise like escaping air and power is immediatley down.
Anyone know if I can pop the dv out without getting the car on ramps?
Steve
Offline gazbutS3
« Reply #18 on: May 27, 2010, 09:00:51 am »
Steve
not on a regular GTI, you really need it on axle stands at least as its bolted directly to the turbo
Offline Pullafacial
« Reply #19 on: May 27, 2010, 07:00:09 pm »
Just booked it in for next week at the garage I bought it from to have a look and investigate a wheel bearing noise as well.
Also, just booked getting my seriously scuffed 18" Monzas in for a "black" makeover aswell.
Can't wait to see the results.
Offline Pullafacial
« Reply #20 on: June 07, 2010, 03:31:11 pm »
Quick update - Took the car in first thing this morning to get sorted.
Just recieved a call to ask if they could keep the car over night as proving a bit more in depth.
Hopefully will know the outcome tommorow!
Offline cuprak1
  • Cupra k1 - 360 bhp/360 ft-lbs
    • London web design
« Reply #21 on: June 07, 2010, 05:13:09 pm »
SpeedStats iPhone app  - AVAILABLE NOW!
View my Cupra k1 project thread here! 360is
Offline Pullafacial
« Reply #22 on: June 08, 2010, 07:27:24 pm »
Well, got the car back today and have a feeling this is gonna take take some sorting!
The garage found a slightly loose pipe which they thought had fixed it but still the same. It just feels really flat and sounds like pressure is leaking before the foot comes of the throttle. garage have said to bring it back and they'll have another look trouble is they're 20 miles away and only open when i'm at work.
They have also established that the wheel bearing noise is infact tyres. they've changed them onto the front but i'm trying to get them to sort it as it drives me mad!
Anyone got any ideas as to what the problem could be? After much reading on here i'd convinced myself it's the DV.
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #23 on: June 08, 2010, 08:47:54 pm »
Some simple vcds logging will confirm if it's a boost leak, and then Replacing the DV is a sensible next step if all the hoses have been checked.
Offline TDIfurby
« Reply #24 on: May 08, 2011, 05:49:59 pm »
Sorry to bump an old thread, but a colleague (with a stock Edition 30) is having a whistling noise but only on tickover, and not from cold.  The whistle goes away on boost and not apparent on cold starts.  Any thoughts?  Suspect the DV is not to blame in this case due to when the whistling is occurring.  :surprised:
Offline 56OctyVRS
  • -Receive: 72
« Reply #25 on: May 14, 2011, 10:45:38 am »
Check the PCV valve as they can create a whistling noise and also lose you power when the check valves inside break.
Saint Steve
« Reply #26 on: May 14, 2011, 07:52:21 pm »
Also hear a hissing sound after shutdown coming from under the top engine cover if the main diaphragm has blown.
