Author Topic: mk5 gti  (Read 3485 times)
Offline titchy
mk5 gti
« on: May 25, 2010, 02:54:39 pm »
got 06 mk5 gti how the hell do you get the top eng. covers off ive tried all morning and afraid they are gonna break. just took it to a local garage and they were afraid they would break them. HELP
Re: mk5 gti
« Reply #1 on: May 25, 2010, 02:57:47 pm »
just give each corner a good pull and it will just pop off
Offline Gti_Mad
Re: mk5 gti
« Reply #2 on: May 25, 2010, 03:37:40 pm »
yh pull each corner up and towards u once there on.... they are a real bugger 2get off jus dnt pull the thin side by the oil cap as dat will break
Offline B3n
  • -Receive: 29
  • Boom!!!!
Re: mk5 gti
« Reply #3 on: May 25, 2010, 04:57:11 pm »
The easiest way i have found is to
Stand infront of your car place one hand on the bottom left of the engine cover then pull the top right of the cover off towards you. It will be a bit stiff but give it a good strong pull then. Before you put the cove back on spreay a lil WD40 or similar on the rubber grommets :happy2:
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
Re: mk5 gti
« Reply #4 on: May 25, 2010, 05:26:53 pm »
.......spot on advice. :smiley:
Offline titchy
Re: mk5 gti
« Reply #5 on: May 25, 2010, 06:36:47 pm »
thanks guys knew id get some help on here
Offline Thor
  • -Receive: 25
Re: mk5 gti
« Reply #6 on: May 25, 2010, 10:29:02 pm »
It can really help to run the engine for a short time to warm up the rubber gromits, makes them much more flexible, and easier to pull off.  :happy2:
                                     Mk6 GTI
  • -Receive: 291
Re: mk5 gti
« Reply #7 on: May 25, 2010, 10:42:06 pm »
Have a read of one of my threads on this. A great amount of effort required.
Offline titchy
Re: mk5 gti
« Reply #8 on: May 26, 2010, 08:47:36 am »
well guys i struggled for half an hour last night managed to shift the r/h side no go on the other side, gonna price up a new cover before i try again. or do i take to vw dealer and ask them to fit new air filter and if they break it!
Offline markymark
Re: mk5 gti
« Reply #9 on: May 26, 2010, 08:50:48 am »
New engine covers are seriously expensive from VW, as Thor said if you try once the engine is warm this will help. I cracked and split an engine cover trying to remove it from a cold engine, I managed to get a secondhand one for £50. You have just gotta be  bit brave and give it a good tug and it should pop off. :happy2:
Offline titchy
Re: mk5 gti
« Reply #10 on: May 26, 2010, 11:29:18 am »
got the damn thing off at last no damage, thanks stealthwolf for threads and the others who replied, back on with plenty of lubricant
Offline cmdrfire
    • Commander Fire - my blog
Re: mk5 gti
« Reply #11 on: May 26, 2010, 12:43:12 pm »
Grab it hard and give it a firm yank. Lube helps.
Saint Steve
Re: mk5 gti
« Reply #12 on: May 26, 2010, 03:50:00 pm »
Oh Reaallly :notworthy:  :signLOL:
Offline cmdrfire
Re: mk5 gti
« Reply #13 on: May 26, 2010, 04:31:52 pm »
Aaaah was wondering why you were after those pics  :signLOL:
