Author Topic: Replacing front fog light  (Read 14889 times)
Offline Russ_leeds
« on: May 25, 2010, 11:19:13 pm »
Is it possible to change the fog light without removing the full bumper? mine got smashed when driving so need to replace. is there a how to guide? tried searching to but no luck? :sad1:
Black 2007 gti, 18' monza 2, sat-nav, highline, i-pod dock, armrest, 35mm H&R springs, WALK, BCS tbe, autotech front and rear arbs, ITG maxogen, NQSBBK... and more to come
  • -Receive: 453
Re: Replacing front fog light
« Reply #1 on: May 25, 2010, 11:29:21 pm »
Just remove the one screw holding the fog grill in, pull out the grill and you can then remove the fog light.
iirc it's held in place by three screws.
Offline McKay88
« Reply #2 on: May 25, 2010, 11:30:45 pm »
Nope just need to remove the fog light cover which is a 20 torx i think then it will just pop off... Behind that their will be 3 25 torx holding the fog light in. Just unplug and then install the new one.
Should only take 5 mins very simple..
Hope this helps :happy2:
  • -Receive: 453
« Reply #3 on: May 25, 2010, 11:32:12 pm »
Offline Russ_leeds
« Reply #4 on: May 25, 2010, 11:34:30 pm »
cheers guys  :happy2:
much appreciated
