Author Topic: What is best for Neg Camber?  (Read 11323 times)
Offline geordie56
« on: May 27, 2010, 06:11:42 pm »
I am fitting my TT arms this weekend along with WALK and just want to know peoples experiance with best settings for the adjustment of the camber? what are you using and what is best for tyre wear etc...? Cheers.
Re: What is best for Neg Camber?
« Reply #1 on: May 27, 2010, 06:29:03 pm »
WALK only effects (and improves) castor.
TT arms will introduce a very small but helpfull amount of camber and apparently has no adverse effect on uneven tyre wear.
HTH  :happy2:
Offline Janner_Sy
  • -Receive: 113
« Reply #2 on: May 27, 2010, 06:42:45 pm »
i very much doubt that winding the TT arms to their maximum egative camber will have a bad effect on the tyre wear.  on a standard car they will allow you to reach 1.5Degree negative camber(1 degree std iirc).  on a lowered car that will increase slightly due to the geometry changes of the suspension.
this guy has them on his so you could always ask him if you wanted.
http://www.audi-sport.net/vb/showthread.php?71940-TT-suspension-arms-fitted-to-my-A3!!!&highlight=tt+lower+arms
most of the cars on track days that want agressive settings, run 3 degrees or more
Offline jabbalad
    • Jabbasport
« Reply #3 on: May 28, 2010, 09:32:25 am »
I run 3 degrees on mine up front, i dont really get any odd tyre wear, they wear really flat actually.... but then it does get used fairly hard  :pomppomp:
12.7 santapod... soon to be quicker :-)
Candy White Edition 30; Custom KW clubsports, Eibach hollow arbs, Jabba remap, BTB Exhaust, Twintake, Autotech HPFP, Team Dynamics wheels, VWR Big Brakes.
« Reply #4 on: May 28, 2010, 10:00:45 am »
I don't think yours is a good example of everyday use, jabba  :grin:  :happy2:
Offline jabbalad
    • Jabbasport
« Reply #5 on: May 28, 2010, 10:03:43 am »
Actually i have done 10,000 miles since december, and its been at those settings ever since i first fitted the suspension back in may last year! :laugh: it is still my everyday car but dont know how i have done that many miles tho!! haha
« Reply #6 on: May 28, 2010, 10:26:31 am »
I have got somewhere around 2 degrees on mine and i found the best way to keep tyre wear even is just go round corners faster than you would straights.  :laugh:  works for me.
« Reply #7 on: May 28, 2010, 10:43:21 am »
This isn't helping me delay spending on TT wishbones!  :P  :laugh:
Offline jabbalad
    • Jabbasport
« Reply #8 on: May 28, 2010, 12:35:34 pm »
You know you want to  :grin:
Offline Janner_Sy
  • -Receive: 113
« Reply #9 on: May 28, 2010, 12:36:12 pm »
what are you running mate.  top mounts i presume??
Offline jabbalad
    • Jabbasport
« Reply #10 on: May 28, 2010, 12:47:48 pm »
Yea KW top mounts and suspension set so the wishbones are level, just need to make some adapters to drop the track rods so there level with the wishbones  :smiley:
Offline Janner_Sy
  • -Receive: 113
« Reply #11 on: May 28, 2010, 12:50:36 pm »
doesnt the whiteline bumpsteer kit change the angle of the track rod ends??
Offline jabbalad
    • Jabbasport
« Reply #12 on: May 28, 2010, 12:59:26 pm »
Yea but try finding them! :sad1:
I tryed everywhere, but they all said they were on back order with no production date, whiteline themselves didnt seem to know they even made them  :confused:
Offline laurent.d
« Reply #13 on: May 28, 2010, 01:04:07 pm »
I have more than 2° of negative camber at the front  :happy2:  thanks to Morego wishbones and a kind of WALK kit but from VWR.
I have got even tyre wear with 80% of highway 20% of bake twisty road and about 30 Nürburgring laps.
A3 2.0 tfsi DSG S-Line/VWR K04 Turbo kit/Engine Revo Stg 3/Milltek Exhaust/DSG Revo Stg 2/Quaife LSD/Bilstein PSS10/H&R sway bars/Power Grip Morego/VWR Suspension Bushes/VF Engineering Engine Mounts/VWR Lower Mount/OZ Ultraleggera 8x18 ET45/Brembo 328x28 2pcs 4 pot ''A'' caliper/Braille Battery
Offline geordie56
« Reply #14 on: May 28, 2010, 07:47:22 pm »
Spot on fellas cheers for your help once again. I shall let you know how i go on over the weekend i am fitting the wishbones, WALK kit and poly bushes , H&R Front and Rear ARBs, Neuspeed Drop Links and VWR lower engine mount.
