Author Topic: Almost stalling on idle  (Read 10854 times)
Saint Steve
Re: Almost stalling on idle
« Reply #15 on: May 31, 2010, 09:31:19 pm »
Just for the record, mine was missfiring on throttle back aswell.
Did you listen for any hissing sound after you shut the engine off under the airbox?.
That'll be were the crankcase pressure will be blowing into the cabin.
Offline zub-gti
« Reply #16 on: June 04, 2010, 09:31:16 pm »
Not getting any hissing on shutoff, but have noticed the DV to be noisier than usual as well as the exhaust note.
Engine management light came on tonight.. Should I be worried?
I have to take the wife to work tomorrow, no other option...
However my bsh pcv revamp and stage 2+ catchxan kit is at the postoffice and I'll get it fitted tomorrow..
All going to plan and she should be back to normal before lunchtime...   :happy2:
Otherwise it's something else  :scared:
I expect the engine management light won't just go out on resolution of the problem and will stay on until reset using vcds??
Saint Steve
« Reply #17 on: June 04, 2010, 09:33:43 pm »
^^ you may find it will go out, but the fault code will stay logged untill its cleared by vcds :happy2:.
Is the car remapped? and have you ever removed it to check its condition.
They are a known weak point (DV's) on mapped std GTi's and should be upgraded to a later version of valve. Later ones were more durable.
If thats  failed, then you would of noticed poor boost.
Fingers crossed this works  :happy2:
Keep us informed :smiley:
« Last Edit: June 04, 2010, 09:40:48 pm by Saint Steve »
Offline zub-gti
« Reply #18 on: June 06, 2010, 08:37:23 am »
Well the catch can kit arrived; collected it yesterday morning at 0700 ready to get it installed..
However I was raging to find that there are parts missing and it's about as much use as
a chocolate fireguard right now...
The 3 x screws that hold the inlet Manila isolation cap are missing..
I also discovered that the instructions are useless and that that the fitting is not meant for a UK car..
So not very pleased right now...
Saint Steve
« Reply #19 on: June 06, 2010, 02:53:03 pm »
Just put the oem Pcv in fella. Forget the catch can personally
Offline zub-gti
« Reply #20 on: June 06, 2010, 05:40:11 pm »
Too late, I already bought the catchcan kit.
At least it's going to stop this happening again.
I don't have a map, but planning on a bluefin pretty soon.
Going to get a service and fault check up before that though.
Should I be hearing the standard DV hiss on gear change?
If I were to replace the DV what is the best on to replace with, oem or an uprated item?
Saint Steve
« Reply #21 on: June 06, 2010, 05:52:44 pm »
Yes
Oem. Later version is better
Offline zub-gti
« Reply #22 on: June 10, 2010, 05:31:14 pm »
So, I decided to have a go at fitting this £180 piece of Kit..... although i'm still waiting for the set screws to arrive from Dubtek...
Found some screws that will fit in the meantime...
To be honest the whole thing has been a disaster... and from what I've read not the first time from BSH..
Pros
 - Good, solid quality machined adapter plate
 - Large, substantial catch can
Cons:
 - No hose clamps supplied (BSH claim not required, but leaves the product unfinished in my opinion and for all the cost should be included for a professional product).
 - OEM hose does not fit correctly over the nipple supplied and leaves some risk of vibrating loose. I have secured with tie wrap.
 - Missing parts (screws) (Dubtek's issue)
 - Unit not designed to fit UK car (Charcoal filter in way, therefore supplied bracket is useless).
 - Insructions are useless
Not impressed, and had it not cured my idle and PSV issue completly I would not recommend.
Saint Steve
« Reply #23 on: June 10, 2010, 11:38:45 pm »
So did the New PCV improove your idling issue Zub??
Offline zub-gti
« Reply #24 on: June 11, 2010, 07:33:54 am »
I don't have a new PCV... It has been replaced by a BSH catchcan..
And 'yes' everything you said in the post is correct...
Idle
Smell
Backfire
100% the OEM PCV was the issue...
Thank you
Saint Steve
« Reply #25 on: June 11, 2010, 07:50:15 am »
Happy days   :drinking:
Oem pcv to install  :wink:
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #26 on: June 11, 2010, 08:43:43 am »
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #27 on: June 11, 2010, 08:57:20 am »
Yes
really Steve ?
I have to say with a standard intake I think I have heard my DV release only once since I bought it.
Only really can be heard on cars with intakes
Red ED35 5dr DSG
BLOG | BUILD
Saint Steve
« Reply #28 on: June 11, 2010, 04:46:14 pm »
i can hear mine everyday john  :stupid:
Saint Steve
« Reply #29 on: June 11, 2010, 04:53:58 pm »
Waste of money catch cans imo.
yet to hear or see a GTi with intake issues due to blocked induction system, plenty of scary photo's but still no failures in this country with the fuels and engine oils we use.
Now wheres my Tin helmet :signLOL:
