Author Topic: Neuspeed rear anti roll bar and neuspeed drop links  (Read 25944 times)
Offline xxx_mojo_xxx
  • MUBster DUBster
Re: Neuspeed rear anti roll bar and neuspeed drop links
« Reply #30 on: October 09, 2009, 11:24:27 pm »
It's been three weeks since I've had the H&R ARBs installed.  I've developed a peculiar knocking noise - which just so happens to occur when turning aggressively left or right from the rear.  Some times the knocking can happen by simply going over a slightly uneven road.
  • From what I read in this thread..are the NeuSpeed drop links likely to resolve this issue?
    Has anyone had any problems with them?
    What other alternatives are there out there (i.e. to Neuspeed)?
    Also, can you get drop links for the fronts?
« Last Edit: October 09, 2009, 11:26:33 pm by xxx_mojo_xxx »
« Reply #31 on: October 09, 2009, 11:47:30 pm »
Kw do front drop links for the clubsports coilovers
  • MUBster DUBster
« Reply #32 on: October 24, 2009, 11:55:04 am »
Ordered a set of BSH drop links.  Thanks for the tip MATT ED30 :drinking:
I'll keep everyone posted on how things go once I get them in the next couple of days...
Offline SteveS
« Reply #33 on: November 30, 2011, 02:42:34 pm »
Bit old i know, but...
I wonder if this is my issue with wheel hop and noise.. I don't believe my front droplinks were changed. I should check to make sure there not broken also.
They are the eibach ones. Do they do drop links? (googling now)
SOLD!! :(
VW GTI Edition 30 No. 0551
Revo Stage2+ (LT) | Evoms Intake, K&N Filter | VWR LSD | Milltek R32 TBE | VWR Engine Mounts | VWR Big Front & S3 Rear Brakes | VWR Springs |  VWR Shortshift | SuperPro Bushes |  Recaro Seats
  • MUBster DUBster
« Reply #34 on: July 16, 2012, 06:04:33 pm »
Just to put this mystery to rest... turned out that one bolt was slightly loose on one of the rear shocks.
