Author Topic: Problems with boost pressure 5000-7000 rpm  (Read 3432 times)
Offline Sagild
« on: May 28, 2010, 09:33:36 am »
Hi guys
One of my friends was at Wörthersee and got his car a revo stg 2 map. At first the car was driving nicely but when he got home to Denmark he started experiencing what feels like serious boots problems from 5000-7000 rpm. Its like the car looses all pressure for like half a sec. or so (300-500 rpm), and then it returns and goes away again, and returns.
The car is a Seat Leon 2.0 TFSI 2006 which has done aprox. 70.000 km. it has 3"TBE, BSH intake, Forge DV and the cam follower was replaced 6.000 km ago. He has changed what he calls "thrust sensor" to the newer K version, cause he has read that might be the reason online, but no help. He then tried to change fuel filter with no luck either.
He drives our vpower which is ron 99 and Revo setting B7 T4 F9
It seems like others are experiencing the same problem, but he says there's no solution to be found online. I stated that you guys most def. would be able to help, so i am hoping not to let him down  :signLOL:
Phantom Black Audi A3 - 2,0 TFSI - quattro - 2006
K04, S3 IC, BSH True seal, APR HPFP, ATP 3" catless DP, Milltek CBE, Eibach Pro-street, Forge short shift, 034motorsports engine & torque mount, NGK Racing plugs, S3 Brakes, Powered by REVO
Offline PDT
  • -Receive: 142
Re: Problems with boost pressure 5000-7000 rpm
« Reply #1 on: May 28, 2010, 01:52:45 pm »
log the AFM, Boost actaul and requested and rail pressure actual and requested.
« Reply #2 on: May 28, 2010, 05:34:23 pm »
Those settings are relatively mild, so I wouldn't have thought that they should cause issues.
Boost act v's requested
Rail pressure act v's requested
cylinder 1-4 timing
These logs should give some insight :happy2:
Offline Sagild
« Reply #3 on: May 30, 2010, 12:01:28 am »
I have asked my mate to log it, so i'm just waiting till he gets a hold on a cable and i'll post the results asap
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #4 on: June 01, 2010, 10:16:13 pm »
He could be getting fuel cuts but that's just a guess.
There is no way of knowing though without looking at logs so as has been mentioned get him to get it logged
Blocks 115,230 & 020
Offline Sagild
« Reply #5 on: June 07, 2010, 10:33:36 pm »
i have told him to log, but this weekend there has been held Denmarks Fastest Car show so i think he has been busy - but before that he was to get a hold on the vcds cable to log the car...
Offline bobsey
« Reply #6 on: June 08, 2010, 07:21:32 pm »
My edition 30 DSG seams to have the same problem at around 5500 rpm, then it recovers shortly after.
Thats also running revo stage two map with a milltek turbo back exhaust and a pipercross panel filter. The revo settings are set on B5 T7 F9.
Any ideas would be appreciated cheers.
Offline Blade
  • Taking a sabatical from cars
« Reply #7 on: June 08, 2010, 08:20:47 pm »
Those settings are probably causing a few issues. Timing high, boost low. Are you running super octanne fuel?
Offline KRL
  • -Receive: 29
« Reply #8 on: June 08, 2010, 10:15:27 pm »
I reckon he may have posted the boost and timing the wrong way round  :wink:
Offline bobsey
« Reply #9 on: June 09, 2010, 01:30:43 am »
Yeh im running my car on super octane fuel from tesco. What settings would you recommend for my spec? And i did get the boost and the timing the right way round, thats what i was recommended.
Cheers.
Offline Poppa Dom
« Reply #10 on: June 09, 2010, 09:14:58 am »
Try running B7T5F9, on Stage 1 majority of people will run boost at either 6 or 7, with timing 5, especially this time of year with the warmer weather.
Offline bobsey
« Reply #11 on: June 09, 2010, 11:36:18 pm »
Ill give thoughts settings ago and see if the problem goes away. Cheers.
Offline xht20
« Reply #12 on: July 13, 2010, 06:27:39 am »
could it be misfire?
