Author Topic: rear wiper removal problem  (Read 2725 times)
Offline Howardvwgolf
« on: May 30, 2010, 05:29:48 pm »
ive just removed the rear wiper. the problem im having now is that the washer fluid still pumps if you operate the stalk, but in a thread on another site it said that the fluid doesnt pump once the  wiper motor assembly is taken off? so what should i do to stop the fluid pumping into the boot?any thoughts guys, i know a few of you have done this mod
Re: rear wiper removal problem
« Reply #1 on: May 30, 2010, 05:51:24 pm »
It can be capped off back at the washer end. Also you can clip it off at the tailgate end just in case you ever want to re-instate it. Thought about this mod myself, but the rear wiper is a godsend in winter and bad weather.
« Reply #2 on: May 30, 2010, 06:03:24 pm »
i thought about just bending the pipe back on itself and cable tieing it, but i dont want the pipe to split. So now im thinking of getting a washer hose Y connector, plugging one part in the end of the pipe which connected to the wiper, and then putting a piece of rubber pipe connecting the other two parts of the 'Y' together
Offline ashley
« Reply #3 on: May 31, 2010, 09:17:22 am »
 I plugged the hole and then disabled the rear wiper via Vag.com. Worked a treat :happy2:
« Reply #4 on: June 01, 2010, 09:46:13 pm »
When i did mine we disabled it with VCDS but then the front ones wouldn't work, all that is needed is to block the pipe.  :smiley:
Offline joesgti
  • Eat my sick, Eat my sick.
« Reply #5 on: June 02, 2010, 10:47:31 am »
mines done through vcds, and my fronts still work.  :smiley:
Offline ashley
« Reply #6 on: June 02, 2010, 10:09:06 pm »
Same here, Come on TC sort you coding out  :wink:
