Author Topic: Fault Codes - where to get more info  (Read 3704 times)
Offline rallycross
« on: January 20, 2009, 11:16:19 am »
Hi
where is a good site to get detail behine fault codes.
I've got a P0441 code, Mk5 Gti, its related to evap' tank.
Offline broke.
Re: Fault Codes - where to get more info
« Reply #1 on: January 20, 2009, 11:44:31 am »
Evaporative Emission Control System Incorrect Purge Flow
This indicates that a part of the EVAP control system is no longer fuctioning correctly. The EVAP system consists of many parts, including (but not limited to) the gas cap, fuel lines, carbon canister, purge valve, and other hoses. The (EVAP) emission control system prevents the escape of fuel vapors from a vehicle's fuel system. Fuel vapors are routed by hoses to a charcoal canister for storage. Later, when the engine is running a purge control valve opens allowing intake vacuum to siphon the fuel vapors into the engine.
EVAP emission canister purge is contolled by a valve which allows engine vacuum to pull stored fuel vapors from fuel tank into the engine to be burned, rather than be vented to atmosphere. A vacuum switch is used to detect when flow exists. If the PCM commands purge and sees that the switch is closed (indicating no detected purge flow) P0441 is set.
no symptoms will be discernible to the driver, other than the illuminated Check Engine Light.
code P0441 could mean one or more of the following has happened:
Bad vacuum switch
Broken or damaged EVAP line or canister
Open in PCM purge command circuit
Open or short in Voltage feed circuit to Purge Solenoid
Faulty purge solenoid
Restriction in EVAP solenoid, line or canister
Corrosion or resistance in purge connector
Bad PCM
Possible SolutionsWith a P0441 OBD-II trouble code, diagnosis can be tricky at times. Here are some things to try:
Common Chrysler fix - Replace Leak Detection Pump / LDP
Repair damaged EVAP lines or canister
Repair open or short in voltage feed circuit to Purge Solenoid
Repair open in PCM purge command circuit
Replace purge Solenoid
Replace vacuum switch
Repair restriction in Evap line or canister or soleniod
Repair resistance in purge connector
Replace PCM
Hope this helps mate  :happy2:
