Author Topic: Glovebox removal question  (Read 10218 times)
Offline micaerin
  • -Given: 19
« on: June 01, 2010, 12:09:51 pm »
Has anyone ever attempted replacing a glovebox?, or is there a how to anywhere
thanks in advance   :smiley:
2007 GTI DSG, Xenon's, Armrest 6 Disc ,Rear Parking Sensors,Sunroof,Lux Pack,Cruise,Electric drivers seat,MFSW,RNS 510,Miltek Cat Back.
Offline S2 Ant
  • -Receive: 21
Re: Glovebox removal question
« Reply #1 on: June 01, 2010, 12:12:19 pm »
I could do with this info as well as i've got the panel that surrounds the glovebox to replace - so i can get rid of the factory car cradle thing and not leave a big hole in the dash
Ant
Offline snapey
« Reply #2 on: June 01, 2010, 12:15:03 pm »
Pop out the few bits of trim around the glovebox, there should then be about 7 torx screws holding it in place, whip them out and it should pull out. There will be a couple of wire connections, one for the lighting, airbag and a small piece of pipework for the glovebox A/C that need disconnecting.
The re-build is exactly the opposite.
Luke.
If you have to ask why, you'll never understand.
Offline Norbreck21a
« Reply #3 on: June 01, 2010, 04:04:39 pm »
As Snapey said but with a picture from Elsawin
Removal
–   Switch off ignition.
–   Remove side dash panel cover on front passenger side → Chapter.
–   Release sill panel moulding from body, in area of transition to lower A-pillar moulding:
t   Two-door → Chapter
t   Four-door → Chapter
–   Remove A-pillar lower trim on front passenger side → Chapter.
–   Remove centre cover → Chapter.
–   Remove the seven bolts -1-, -2- and -3- (1.5 Nm).
–   Slide glove compartment outwards onto limit stop -arrow A-.
–   Detach glove compartment -arrow B- from dash panel.
–   Disconnect wiring harness from light and contact switch.
–   If vehicle is equipped with front passenger airbag disabling, disconnect wiring harness from key switch.
–   If vehicle is equipped with glove compartment cooling, disconnect air conditioning duct from glove compartment.
–   If vehicle is equipped with a footwell light, disconnect wiring harness from light
Offline parks
  • Red ED30 No. 1778 Detailing World member
« Reply #4 on: March 30, 2012, 10:05:10 am »
trying to use this pic as a guide, i cant seem to find the last screw, the left 'number 3'
i think it maybe above the gear stick but cant remove the trim  :sad1:
Standard: Rear parking sensors, Parrot Bluetooth
Retro fitted: MFSW buttons, RCD510, Boot pop, Black Monza II, Xenons, Audi jacking points, open fog light grills.
Offline micaerin
  • -Given: 19
« Reply #5 on: March 30, 2012, 10:33:25 am »
You have to prise off a plastic cover to see it, easy once you see it
Offline parks
« Reply #6 on: March 30, 2012, 11:10:59 am »
popped off cheers.
got the whole glove box out and found the culprit... a small while cog had come off its runner. sorted now and working smooooth again..
only trouble is re fitting the whole thing  aarrrrgggghhhh!!
