Author Topic: R888 on the road  (Read 4121 times)
Re: R888 on the road
« Reply #15 on: June 02, 2010, 07:15:13 pm »
if they are 27psi cold what would that equate to when warm.  he'll have to drive to the station to do the pressures so no doubt they will be warm with the weather and that drive when he gets there
Or how long should I wait, after a slow drive to the garage? 2 miles (ish)
Offline jonnyc
  • Herrooooo!
« Reply #16 on: June 02, 2010, 07:15:42 pm »
Best to set pressures when the car has been sat out of the sun.. So say early morning.. Did they use dry air?
Its worth checking anyways, most likely they will be around 35psi which is waayyy too much for those..
« Reply #17 on: June 02, 2010, 07:24:04 pm »
Dry air?  Their air gun was spraying water mist everywhere so they probably had w*nk  pneumatic system.
Went to cowboy tyre fitters round the corner as I knew they would fit tyres I supplied.
Offline tony_danza
  • -Receive: 112
« Reply #18 on: June 02, 2010, 07:28:01 pm »
TD what are the benefits of running toe in/out or parallel etc.  also what pressures dop people run their R888s on. mike maywell have them over pumped
Oh God, the subject goes on and on and on, it also is very much determined by what the driver's style is - they'll listen to what he wants and set it up accordingly I'm sure.
I think they run 28F 30R, my PSCups are around 2PSI higher all round by comparison, really depends on the tyre.
Nitrogen infaltion FTW - water vapour = massive changes in cold/hot pressure leading to greasy tyres and crowning.
« Last Edit: June 02, 2010, 07:29:59 pm by tony_danza »
Sideways yo!
« Reply #19 on: June 02, 2010, 11:42:07 pm »
You was right jonny, they put 36psi in them!  :fighting: :fighting:
Offline jonnyc
  • Herrooooo!
« Reply #20 on: June 02, 2010, 11:49:44 pm »
Lol.. Yeah that's quite a lot.. Feel better now?
« Reply #21 on: June 04, 2010, 12:24:48 am »
They grip ace!  Had geo checked today aswell.  Did toe on front and toe and camber on back.  Will scan the print out tommorow
