Author Topic: Revo Ed30 Fails MOT on Emissions  (Read 20881 times)
Offline Rob GTI
« on: June 03, 2010, 09:48:58 pm »
Well nearly....
The car is 3 yrs old at the end of the month and I thought I'd get the MOT early in case there are any issues that I can get sorted under warranty.
Anyway the car nearly failed on the emissions well technically it did but the tester gave me a pass with an advisory. The lambda reading was 1.7 and needs 1.3 to pass. It was suggested that the car was running lean.
I have REVO stage 1, dbilas intake and milltek TBE. I switched the map off and it still failed, no codes are logged with VCDS, anyone got any ideas?
GTI Edition 30 No. 907, 3 door, Black. (Now Sold)
Offline cuprak1
  • Cupra k1 - 360 bhp/360 ft-lbs
    • London web design
Re: Revo Ed30 Fails MOT on Emissions
« Reply #1 on: June 03, 2010, 09:51:06 pm »
de catted ?
SpeedStats iPhone app  - AVAILABLE NOW!
View my Cupra k1 project thread here! 360is
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #2 on: June 03, 2010, 09:51:56 pm »
Or faulty Cat?
Offline jhtrophy
  • Oh no it's a diesel
« Reply #3 on: June 03, 2010, 09:54:22 pm »
you running v power? does it need a thrapping?
« Reply #4 on: June 03, 2010, 09:54:47 pm »
Probably best that you take this up with REVO rather than a bunch of strangers guessing............................
Offline Rob GTI
« Reply #5 on: June 03, 2010, 09:54:55 pm »
No not decatted, single Milltek sports cat on it.
Btw: REVO settings are B7 T5 F7
Offline Rob GTI
« Reply #6 on: June 03, 2010, 09:58:48 pm »
Aye I will do that tommorrow, well with my tuner first and then REVO. Just thought I'd ask here first in case anyone else had similar.
Strangers??? I'd though we were all friends here  :grin:
« Reply #7 on: June 03, 2010, 09:59:16 pm »
as jhtrophy says you need to get the cat red hot before the test ie go rape it  :grin: as thats what will need doing
Offline Rob GTI
« Reply #8 on: June 03, 2010, 09:59:48 pm »
Always run on V Power or Tesco 99.
Always given a thrapping too.
« Reply #9 on: June 03, 2010, 10:00:45 pm »
Some are stranger than others!  :laugh:
Offline Rob GTI
« Reply #10 on: June 03, 2010, 10:02:02 pm »
Aye my tuner recommended that as well (before the test - not spoke to then since). It had been driven for about 45 prior to test, including one brief trip to the red line in 2nd. What with the 25 degrees outside I though that would be enough.
« Reply #11 on: June 03, 2010, 10:03:14 pm »
well it need plugging into vagcom and logging doing i think but Revo can do that for you
Offline Rob GTI
« Reply #12 on: June 03, 2010, 10:17:08 pm »
best ask my tuner what to log then as I new to VCDS and only really know how to run a scan and change a few comfort settings.
Offline Janner_Sy
  • -Receive: 113
« Reply #13 on: June 03, 2010, 10:29:22 pm »
timmyboy on here(with a vRS) failed his mot on missions, it turned out to be his cat on his piper downpipe was fooked.  he changed Dp and all was good
Offline paulk
« Reply #14 on: June 03, 2010, 10:34:10 pm »
did you give the car a good run and warm up before the mot..
