Author Topic: Exhaust Gas Warning Lamp  (Read 2873 times)
Offline mb
  • -Receive: 29
« on: June 05, 2010, 10:37:48 pm »
Hello
The exhaust gas warning lamp came on earlier today as I was driving.  Checked the manual and it says could be lambda sensor.  Had a quick search on here and not that many posts regarding a similar fault.
I've got VCDS so will do a scan tomorrow (not that I know what I'm looking at ha ha!).  Shall I attempt to clear the fault and see if it comes back or take it to VW?
Am I ok to keep driving as the car doesn't feel any different?
Re: Exhaust Gas Warning Lamp
« Reply #1 on: June 05, 2010, 10:39:31 pm »
Scan it and post it up on here. That light can come on for a lot of reasons.  :wink:
Offline mb
  • -Receive: 29
« Reply #2 on: June 06, 2010, 12:07:56 pm »
Here's the scan:
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115 J    HW: 1K0 907 115 F
   Component: 2.0l R4/4V TFSI     0030
   Revision: --H14---    Serial number: VWZ7Z0F3751704
   Coding: 040300031C070160
   Shop #: WSC 00670 210 91754
2 Faults Found:
012599 - Intake Manifold Runner Control: Basic Setting not Completed
               P3137 - 001 - Upper Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 48668 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 60.0°C
                    Temperature: 55.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 12.065 V
001602 - Sensor Reference Voltage A: Circuit: Low
               P0642 - 002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 48668 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 60.0°C
                    Temperature: 55.0°C
                    Voltage: 9.779 V
Readiness: 0000 0000
Had a quick look on the Ross Tech website but it all means nothing to me!
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #3 on: June 06, 2010, 01:41:31 pm »
I would flow this process to start with for the first fault code: -
http://wiki.ross-tech.com/wiki/index.php/2.0l_TFSI_(AXX/BGB/BPJ/BPY/BWA)#Intake_Manifold_Runner
« Reply #4 on: June 06, 2010, 01:45:16 pm »
Damn, was just about to post that link Steve...
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #5 on: June 06, 2010, 01:45:55 pm »
Sorry Doc  :innocent:
Offline mb
  • -Receive: 29
« Reply #6 on: June 06, 2010, 03:38:07 pm »
Thanks for the replies guys.
I've gone through the process in the link, do I now have to clear the fault codes and see if the error comes back or should it clear itself?
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #7 on: June 06, 2010, 03:39:36 pm »
Yes clear the faults now  :happy2:
Offline AlanD
« Reply #8 on: June 06, 2010, 03:39:51 pm »
You will need to clear the fault code otherwise it will never go.
:edit: Steve strikes AGAIN !
Offline mb
  • -Receive: 29
« Reply #9 on: June 06, 2010, 03:41:51 pm »
I thought I would have to clear them but wasn't sure, still new to this VCDS stuff!
Just clearing now.....
Offline mb
  • -Receive: 29
« Reply #10 on: June 06, 2010, 03:52:03 pm »
Success!!  The fault has now gone.
Thanks again guys  :happy2:
« Reply #11 on: June 06, 2010, 04:42:57 pm »
Fingers crossed that it doesn't come back...   :happy2:
