Author Topic: wet boot floor on pass side 06 gti 3 door  (Read 2727 times)
Offline mk2mexico
« on: June 08, 2010, 09:07:35 pm »
Wet boot floor on pass side 06 gti 3 door??
 :sick:
jacko78
Re: wet boot floor on pass side 06 gti 3 door
« Reply #1 on: June 10, 2010, 01:30:01 am »
I too have this problem
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #2 on: June 10, 2010, 06:05:25 am »
Do your rear washers work ok?
Sometimes the washer pipe can become detatched on it's path the the rear of the car.
Stu...
Offline Mandy
  • -Given: 95
  • -Receive: 94
« Reply #3 on: June 10, 2010, 02:29:54 pm »
^^^^ Yeah, what he said... My boyfriend had this problem but it was his interior lining (C-pillar?) on the passenger side that got wet, not the boot. Apparently it was due to c**p screenwash? Who knows  :confused:
Offline big al
« Reply #4 on: June 10, 2010, 05:23:34 pm »
My boot has a bit of damp in it so I went on e bay and got one of the rubber boot mats, have only had it in a very short time, so do not know if it has worked yet or not, keeps the stuff in the boot from rolling around though!
Offline mk2mexico
« Reply #5 on: June 12, 2010, 09:53:17 am »
how do you find the washer pipe??
Offline ashley
« Reply #6 on: June 12, 2010, 02:25:56 pm »
Surely this will just cover up not prevent the leak. But yes they are good to stop bits rolling.
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
« Reply #7 on: June 20, 2010, 05:41:15 pm »
A known issue is problems with the rear seals. This can result in water getting into the boot or the rear light cluster. Best advice is to empty the boot, line it with newspaper, then get busy with a hosepipe or jetwash. You'll soon know whether it's the seals or a washer hose!
Offline gileshanna
« Reply #8 on: August 02, 2010, 07:38:15 pm »
We have had cars at work (main dealer) having poor rear end repairs around the bumper brackets. You'll need to remove rear bumper and you'll see where it is coming in.
