Author Topic: intake survey?  (Read 15136 times)
Re: intake survey?
« Reply #30 on: June 13, 2010, 07:49:59 pm »
Sorry folks but in the light of different MAF pipe sizes my question was genuine and not intended to kill the survey.
Offline Janner_Sy
  • -Receive: 113
Re: intake survey?
« Reply #31 on: June 13, 2010, 07:52:10 pm »
it doesnt matter, MAF output is a very good guide for how well a car performs and how well the intake can flow.  you'll have to speak to JKM for your logs if you  want to know your MAF Robin :happy2:
Re: intake survey?
« Reply #32 on: June 13, 2010, 08:35:51 pm »
Cheers, Sy - I'll see if I can get my flow log from JKM for the sake of adding info to this survey.
Offline Poverty
  • -Given: 36
  • -Receive: 21
Re: intake survey?
« Reply #33 on: June 13, 2010, 10:52:18 pm »
will evoms readins be accurate seeing as they have non std maf housing sizing?
None of the readings will be bang on accurate whether it is the ITG, EVOMS Twintake etc....
To get an idea of how accurate the reading is look at your long term fuel trims (LTFTs)  this will tell you how much fuel the ECU is having to add or subtract to maitain AFR.  To check your LTFTs look at block 31.
You really do know your way around vcds  :happy2:
I know who I will be begging for help should I ever need it  :signLOL:
Offline Poppa Dom
Re: intake survey?
« Reply #34 on: June 13, 2010, 10:57:41 pm »
For what it's worth my ltft is -2 and my stft is generally between -3 to 0
Re: intake survey?
« Reply #35 on: June 15, 2010, 02:48:21 pm »
K04 Cars
TFSI_mike===stage 2+ APR===ITG===248g/s
gazbutS3=== stage 2+ REVO===ITG===255g/s
cupra_k1===stage 2+ REVO===ITG===261g/s
KRL===Stage 1 REVO===Twintake===249g/s
DJhorice===stage 2+ revo===Evoms===275g/s
Hedge===Stage 3 Superchips===stock intake===259g/s
DomT===Revo Stage 2+/Stage 2 DSG===Evoms===277g/s
PDT===Revo stg2+===Dbils intake with open cone inplace of airbox===256g/s
GTiJames== Revo Stage 2+ == ITG == 251.1g/s
Hurdy===Revo Stage 2+/stage 2 DSG===Evoms==277.67g/s
K03 Cars
vRSCarl===stage 2+ REVO===Evoms===234g/s
vRSy===stage 1 shark performance===stock intake===200g/s
muckipup===stage 2+ shark performance test map===ITG===204g/s
RedRobin===Revo stage 2===Forge Twintake===???g/s [to be added]
Hybrid K04
Steve Jr at Statllers===GIAC hybrid map==Evoms/VF combo===306g/s
Re: intake survey?
« Reply #36 on: June 15, 2010, 02:56:24 pm »
Lol@ Hurdy with 277.67g/s. Guess you wanted to get one up on DomT's 277g/s value.  :laugh:
Offline Aparoon
Re: intake survey?
« Reply #37 on: June 15, 2010, 07:11:38 pm »
  :signLOL:
Was just about to write the same thing ..
Edition 30 DSG, Revo 2+,BSH Intake, Autotech hpfp, Blueflame TBE,  Eibach Sportlines, Speedline Turini's GONE
Offline Janner_Sy
  • -Receive: 113
Re: intake survey?
« Reply #38 on: June 15, 2010, 07:30:43 pm »
think DomT was running 277.68 but didint want to boast :grin:
Re: intake survey?
« Reply #39 on: June 15, 2010, 08:29:16 pm »
Did Hurdy post 277.67? I think that 7 was meant to be a 9, so 277.69   :evilgrin:
Re: intake survey?
« Reply #40 on: June 15, 2010, 09:08:20 pm »
 :P
I did some logs earlier today with this in mind. 3 runs in total with 2 over 277g/s in 4th gear and one at 274g/s in 3rd gear - private road obviously :wink:
Steve Jr has texted me to say that they have some logs with peak flows over 308g/s now :surprised: i think he's aiming for 310g/s and the car goes on Noble's dyno tomorrow afternoon :jumping: , so we should see some good figures with a bit of luck :happy2:
Re: intake survey?
« Reply #41 on: June 15, 2010, 09:12:08 pm »
You got anything for your cylinder timings. All mine are zero apart from cylinder 2 and 3 on one run which ran at around -2 between 2.6k and 3.4krpm.  My LTFT's are zero, but don't see why they should be different to yours :confused:
Offline KRL
  • -Receive: 29
Re: intake survey?
« Reply #42 on: June 15, 2010, 09:25:17 pm »
Very unlikely that your LTFT is 0 mate.  Are you sure you looked at the right block?  Engine block 32 with the ignition turned on is all you need to see it.
Re: intake survey?
« Reply #43 on: June 15, 2010, 09:45:52 pm »
....Best scrub me from the list. No MAF thingy will be forthcoming - Nothing has been logged on the road since Twintake installed and hasn't been necessary.
Re: intake survey?
« Reply #44 on: June 15, 2010, 09:47:47 pm »
LTFT is only zero just after you clear the engine fault codes even thought there were no fault codes.
