Author Topic: intake survey?  (Read 15110 times)
Re: intake survey?
« Reply #45 on: June 15, 2010, 09:59:53 pm »
Steve Jr has texted me to say that they have some logs with peak flows over 308g/s now :surprised: i think he's aiming for 310g/s and the car goes on Noble's dyno tomorrow afternoon :jumping: , so we should see some good figures with a bit of luck :happy2:
Just got the same text, think he's subliminaly selling the GIAC / Hybrid lol
Offline SteveTDCi
Re: intake survey?
« Reply #46 on: June 15, 2010, 10:35:36 pm »
so looking at some of those figures, the ITG doesn't give much over the standard airbox but if you do want a CAI to flow better then get an EVOMS ?
Re: intake survey?
« Reply #47 on: June 15, 2010, 10:37:57 pm »
My LTFT's are zero, but don't see why they should be different to yours :confused:
Very unlikely that your LTFT is 0 mate.  Are you sure you looked at the right block?  Engine block 32 with the ignition turned on is all you need to see it.
I'll check when I get home. I thought it was a little strange as Dom is running the same intake as me. Sure I dialled in the right block though :confused:
Re: intake survey?
« Reply #48 on: June 15, 2010, 10:39:10 pm »
LTFT is only zero just after you clear the engine fault codes even thought there were no fault codes.
Ahh, this may be why as I'd cleared the engine check light fault just before :happy2:
Offline muckipup
  • -Receive: 25
Re: intake survey?
« Reply #49 on: June 16, 2010, 10:40:15 pm »
Well I think looks can be deceptive as per my post earlier - my map meant that I wasn't getting the fuelling which meant that I didn't need the air. It wasn't down to my ITG intake if you get my drift....
...at least, I hope it isn't coz VRSy flogged it to me!  :fighting:  Got a feckin nerve with this thread otherwise  :signLOL:
« Last Edit: June 16, 2010, 10:43:17 pm by muckipup »
Offline Nikiforos
Re: intake survey?
« Reply #50 on: June 28, 2010, 08:33:02 am »
RedRobin===Revo stage 2===Forge Twintake===???g/s [to be added]
 :popcornsoda:
Candy White DSG,S3 full brake setup,S3 I/C,TT Lower Arms,Superpro Bushes&Antilift,
Bilstein custom coilovers,Eibach front- BSH rear ARBs,full Milltek exhaust,e-tuners stage 2 remap.
Offline Janner_Sy
  • -Receive: 113
Re: intake survey?
« Reply #51 on: June 28, 2010, 01:03:25 pm »
I think the fact that the k04 cars are pulling 270g./s out of the same intake with an identical filter and pipework(excluding the DV takeoff)the filter restricts the amount that it can suck in, so its more of a combination of the two.
Re: intake survey?
« Reply #52 on: June 28, 2010, 02:37:08 pm »
:popcornsoda:
....No information available. JKM didn't log such when they installed my Twintake.
