Author Topic: Will a MK6 rear badge fit a MK5?  (Read 13808 times)
Offline bodger00
  • -Receive: 20
  • A wish called Zonda
« on: June 12, 2010, 09:49:11 am »
The MK6 rear badge looks far better than the MK5 one so I am going to change my tatty looking one. Has anyone done this? Are the mounting holes/connectors the same?
Re: Will a MK6 rear badge fit a MK5?
« Reply #1 on: June 12, 2010, 11:34:59 am »
I think it should as SteveP used the Mk6 rear badge for the rear view camera instal on his Mk5.
http://www.mk5golfgti.co.uk/forum/index.php/topic,10027.0.html
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #2 on: June 12, 2010, 08:23:53 pm »
Yep bacillus is correct the Mk6 badge will fit the Mk5 perfectly  :happy2:
Offline bodger00
  • -Receive: 20
« Reply #3 on: June 12, 2010, 09:30:52 pm »
Are you saying the wiring connector is the same? This is on just an ordinary badge not a RVC
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #4 on: June 12, 2010, 09:41:58 pm »
The Mk6 standard badge is a plug and play direct swap for the Mk5 badge.
It's the camera badge that has different loom  :happy2:
beatking
« Reply #5 on: June 13, 2010, 04:47:22 am »
good idea
Offline bodger00
  • -Receive: 20
« Reply #6 on: June 13, 2010, 08:50:59 am »
Thanks all I am ordering one  :notworthy:
Going to attempt without the trim tool - how hard can it be :scared:
Offline 182_blue
  • -Receive: 54
« Reply #7 on: June 13, 2010, 09:04:50 am »
trim tools dont help to much on the boot plastic cover TBH,  if its the first time its been off it will be a bitch lol, you just have to take the two screw out and then remove the bulb covers and yank away, once one or two of the metal clips pop the rest will come
Offline bodger00
  • -Receive: 20
« Reply #8 on: June 13, 2010, 09:05:47 am »
Cheers can't wait to sort out that tatty looking worm ridden badge :signLOL:
Offline mortygttdi
  • -Receive: 146
« Reply #9 on: June 13, 2010, 10:40:42 am »
If its just the badge your after then no it doesn't I've got one here and its a different shape, but the full mech and badge will fit has I have one of SteveP's camera ones that I bought from Jay.
Darren
Offline keith
« Reply #10 on: June 13, 2010, 11:23:59 am »
whats the part number for the mk6 badge minus camera?
From the look of the how to you have to remove the tailgate inner trim to get at the screws?
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #11 on: June 13, 2010, 04:14:36 pm »
Yes the rear trim needs to removed to get to the three screws that hold the badge/release mech in place.
The part number for the Mk6 non-camera badge 6R0 827 469 ULM  :happy2:
Offline bodger00
  • -Receive: 20
« Reply #12 on: June 13, 2010, 04:38:55 pm »
Darren
Confused.   :confused: The badge is the same size, yes? If the mounting holes are in a different place then I can re drill = no hastle. But if the wiring connector is different then = chew, as I'm no electronic engineer.
I'm only going to get a MK6 Standard badge and replace a standard MK5 one.
Does that help?
Offline keith
« Reply #13 on: June 13, 2010, 04:39:53 pm »
Thanks, I went a little last year and cf effect my grill badge and wa :happy2:nted to turn my attention to the rear as its needing attention.
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #14 on: June 13, 2010, 04:43:25 pm »
Darren
Does that help?
He means the chrome/silver piece of the badge that can be separated from the mech (but is not available separately from VW) has different mounting holes/clips compaired to the Mk5 Badge.
