Author Topic: 245 section tyres - will they fit?  (Read 8237 times)
« on: January 22, 2009, 05:00:08 pm »
Alright, I need more grip and I am considering some 17" lightweight alloys for track use and wondered whether or not 245-40-17 tyres would fit okay width-wise.
The radius will be 5mm less than the 225-40-18's but it is the width I'm wondering about. Similarly I believe I would have to have at least 8" alloys for correct tyre width fitment too.
The tyres I'm considering are the Toyo R888's see below.
http://www.tyretraders.com/SearchType/Default.aspx?Width=245&Ratio=40&Rim=17&Manufacturer=TOYO&ItemCategoryID=MOTOR%20SPORT%20TYRES
And this is the calculator I used
http://www.tyretraders.com/Tyrecalculator/
Any input welcome :happy2:
Offline tony_danza
  • -Receive: 112
Re: 245 section tyres - will they fit?
« Reply #1 on: January 22, 2009, 05:14:24 pm »
Funny you mention road legal track tyres, I was speaking to someone today who runs an old factory Leon Cupra Cup car as a track slag and I asked what tyres he used? He said he's found Dunlop DZ02G to be the best, gets a good 6 trackdays (very hard use, soft compound) out of a set if you rotate them and they stick like the proverbial.
Similar in price to R888s and come in either medium or soft compound for about £140-£160 a tyre - something to consider, as a Leon is not far off our size/weight. I think I'll try a set next time.
Sizing, not entirely sure, sorry.
« Last Edit: January 22, 2009, 05:16:37 pm by tony_danza »
Sideways yo!
« Reply #2 on: January 22, 2009, 07:13:37 pm »
I've managed to find a tyre width to rim width calculator too.
http://www.alloywheels.com/tyrecalc.asp
245 section tyres should fit on anything between 8" to 9.5" :happy2:
All I need to know now is will the tyre width fit under the arches okay?
Anyone?
Offline jonnyc
  • Herrooooo!
« Reply #3 on: January 22, 2009, 07:23:40 pm »
You will have a mission making them fit mate but I think it is possible with the correct offset. Also unless you run a lot of camber for the front arches you will rub a lot if you want the car to be low, if its high you probably shouldnt have too much of a problem..
I had 235/40/18 R888's on the S3 and that was with a ET42 wheel, I think with an ET45+ wheel and rolled arches, 2+ degrees negative camber you should have them fit on without too much trouble..
Im trying to get the 265's on but I need 9" rims for that, up to now I have only found a couple of wheels than I can get in the 5x112 with the correct offset.
Send me an email and ill send you an excel document that I have which should help you out with what your doing!
Jonny
« Reply #4 on: January 22, 2009, 07:54:21 pm »
I was thinking about also dropping a size to 17" x 8" alloys.
The new OZ Alleggerita HLT ones look promising at just 6.4kg's each :surprised:
http://www.alloy-wheels-shop.co.uk/p1046745.htm
Thanks for the info. I've sent you the e-mail :happy2:
265's does look like a proper wide tyre and I'm sure that where there's a will there's a way :smiley:
Offline tony_danza
  • -Receive: 112
« Reply #5 on: January 22, 2009, 08:13:24 pm »
So, I looked and they do them in 18"...... DAMN YOOOOUUUUUUUUUUUU!!!!!!
Fantastic sizing, 17x8 or 18X8 5-112 ET48. Not cheap though.  :sad:
« Last Edit: January 22, 2009, 08:19:35 pm by tony_danza »
Sideways yo!
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #6 on: January 22, 2009, 09:27:35 pm »
nice choice of wheel Hurdy  :happy2:
Red ED35 5dr DSG
BLOG | BUILD
Offline jonnyc
  • Herrooooo!
« Reply #7 on: January 22, 2009, 09:32:19 pm »
Looked at them when I was looking at what wheels to get but they were not going to be available until early March apparently.. Couldn't wait that long. They are stunning  :happy2: :happy2:
« Reply #8 on: January 22, 2009, 11:06:06 pm »
Cheers guys.
TD, sorry I wasn't trying to spend your money...honest!! :innocent:
I think I'll try and get my local tyre guys to pop a 245 section tyre on for me to check fitment. :happy2:
Offline ukdub
« Reply #9 on: January 23, 2009, 03:07:32 am »
OZ Alleggerita HLT  :drool: :drool: Toyo R888 :drool: :drool: :drool: :drool:
Where is my credit card?  Been looking for a track wheel.  Thanks Hurdy, you have found them for me :happy2:
Laser Blue with K04 power, APR hardware controlled by REVO 2+ software
Chassis by KW V3's, Whiteline and a hint of PRO race 1.2's
Brakes by Brembo 4 pots
Offline ukdub
« Reply #10 on: January 23, 2009, 03:11:33 am »
Just read all the posts again.  Just a thought Hurdy.  Doesn't your brake set up need a little more room than 17"s or am I having a blonde moment.
« Last Edit: January 23, 2009, 03:24:40 am by ukdub »
Offline tony_danza
  • -Receive: 112
« Reply #11 on: January 23, 2009, 10:27:30 am »
No problem, we've been discussing lightweight wheels for a while over on the dark side actually and it's been noted that some OZ wheels are a little weak, fine for driving, but buckle easily with potholes etc. that's why the Superleggeras were withdrawn.
Even at 1kg per wheel heavier, I think I'd still go down the Speedline route and save myself £450+.
Sideways yo!
Offline The wheel man
« Reply #12 on: January 23, 2009, 12:22:10 pm »
How about a leftfield option........
http://www.radius-autotech.com/index.php?option=com_content&task=view&id=68&Itemid=151
On the tyre side, you should be OK.  Although the Toyo 888 is a straight side wall the width of Toyo's is usually less that otherr brands IE a 245 Toyo would probably be the same measuerd width as, say a 235 Goodyear....  HTH  :happy2:
« Last Edit: January 23, 2009, 12:25:54 pm by The wheel man »
APR cat back, ECS Insert
« Reply #13 on: January 23, 2009, 04:22:03 pm »
Cheers Ben :happy2:
« Reply #14 on: January 23, 2009, 04:24:35 pm »
Not quite blonde, but the TAROX's will fit under 17"'s It is just that some won't have clearance to the spokes. The Alleggerita's have a good spoke clearance and should still fit.
