Author Topic: door handle  (Read 1911 times)
Offline stuupnorth
    • stuupnorth
door handle
« on: June 15, 2010, 07:48:21 pm »
Hi guys
Can anyone help me with this problem?
I'm looking to replace the passenger front interior door handle(3dr)
I know it comes in two parts an outer and the inner part with the
window switch
outer no prob's ,will i have to take the panel off it looks/seems to be fixed
somewher else as i have removed the screws but it won't budge
Stu
Offline big al
Re: door handle
« Reply #1 on: June 16, 2010, 11:33:38 am »
Are you reffering to the interior doorcard?
If so then there are a few screws, there are 2 at the bottom running parallel to the bottom of the door, one around the corner by the side mirror, and the 2 behind the handle once you remove the handle cover.
Then pull really hard, there are just clips holding the card in place after that.
cameluk
Re: door handle
« Reply #2 on: June 16, 2010, 01:26:05 pm »
There are three lower screws on a 3 door
Take a look at this thread http://www.golfmkv.com/forums/showthread.php?t=82260, its for a 5 door, but shows where the screws are located
