Author Topic: ETKA number for plug to fit S6 LED  (Read 6127 times)
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« on: June 17, 2010, 10:36:10 am »
Would be much appreciated  :smiley:
Over the top mod list ;o)
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
Re: ETKA number for plug to fit S6 LED
« Reply #1 on: June 17, 2010, 08:52:25 pm »
Have you got the part number of the LED unit?
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #2 on: June 17, 2010, 08:55:43 pm »
Edit - If the LED unit is 4F0 941 067 A then the three pin connector housing is 3D0 973 703.
Let me know if you need the connector wires as well  :happy2:
  • -Given: 243
  • -Receive: 154
« Reply #3 on: June 17, 2010, 10:08:33 pm »
i'll check the led number tomorrow, i'm hoping that i can dismantle the fog connectors and reuse them in the led connector  :smiley:
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #4 on: June 17, 2010, 10:13:18 pm »
Where did you get the S6 Led from and are you talking about the S6 DRL's?
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #5 on: June 17, 2010, 10:26:49 pm »
These connectors are a couple of pounds each  :happy2:
  • -Given: 243
  • -Receive: 154
« Reply #6 on: June 18, 2010, 07:21:02 am »
yes, they are the S6 DRL LED, and have partnumber 4F0 941 067.A
got them from a private seller on ebay, took the best of 2 month to recieve them but got them finally. i find that they suit the R32 front and since my foglight wiring is doing nothing..... :wink:
  • -Given: 243
  • -Receive: 154
« Reply #7 on: June 18, 2010, 07:23:08 am »
do you think i can reuse the "plugs" from the foglight connectors or do i need repair wires for the S6 connector?  :smiley:
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #8 on: June 18, 2010, 07:58:45 am »
I will check what the fog light connector is when I get back in front of my PC later, but I would expect it to be different.
  • -Given: 243
  • -Receive: 154
« Reply #9 on: June 18, 2010, 11:03:18 am »
you are probably right, but the S6 plug can be had incl. a bit of wiring??  :smiley:
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #10 on: June 18, 2010, 06:54:41 pm »
I can confirm the Fog light connector is a different 2 pin housing so that won't help.
If you order the connector 3D0 973 703 for the S6 LED's then you need the repair wires 000 979 019 E, each wire gives you 2 ends so you will need 3 wires  :happy2:
  • -Given: 243
  • -Receive: 154
« Reply #11 on: July 29, 2010, 01:03:10 pm »
old tread revival:
Fog light is 2 wires each, s6 led 3?? If s6 is to be used for drl, then only 2 wires per led is needed right, not 3?????  :smiley:
« Reply #12 on: July 29, 2010, 02:37:20 pm »
When I was investigated the true LED DRL option for my GTI I came across forum threads in America showing how quite a few guys had fitted S6 LED strip units to their Mk5 R32's. They will also fit the grills of the Mk5 GT but not the GTI without cutting into the crash bar - Not advisable.
Great mod, Jake.. Looking forward to the pics.
