December 22, 2024, 05:17:02 pm
All Things Mk5
Technical Workshop
Coolant...Pls Help
Topic: Coolant...Pls Help (Read 2147 times)
dakk1977
Coolant...Pls Help
January 23, 2009, 03:18:03 pm »
Hi Guys
Im a newbie on this site, i gotta bit of a problem, I seem to be loosing water at about 250 - 500ml between 1200 and 1800 miles driven. Worried this could be the dreaded head gasket, Looking for ideas really as i had issues with my first mkv with my local milton keynes dealership they changed a head gasket and then i started loosing 4ltrs of oil every month!! long long story! So im not to keen to send it to them or at least a little worried.
So im kinda thinking the worst in the hope its something else i have looked and not seen any leaks as yet but i does not usually do this to be honest.
Any ideas??
Top Cat
Top cat
Just look at my post count
-Given: 171
-Receive: 335
Almost Jacamo
Re: Coolant...Pls Help
Reply #1 on:
January 23, 2009, 06:43:10 pm »
Check the inside of the engine oil cap for white gunk, that should tell you if its the head gasket.
It sound more like the coolant res problem that a couple of people have had recently.
Alan D has just had this problem fixed but he doesn't post here very often so either PM him or do a search on the other forum.
Oh and welcome to the forum.
billyboy
Won't Shut up.
-Given: 0
-Receive: 3
Billy lar
Reply #2 on:
January 23, 2009, 07:09:03 pm »
Ive heard this also, something along the lines of coolant leaking from the sensor, as the terms are moulded into the bottle, pull off the wire block and check youd probly see it anyway leaking coz of the G12 is pink and would leave a trail .
billy
winrya
Won't Shut up.
-Given: 7
-Receive: 16
Reply #3 on:
January 24, 2009, 12:04:25 am »
I had mine looked at today, it was leaking from a plastic flange connected to the engine, very common apparently, getting it sorted in april when its serviced and mot'd, can keep topping up once a month until then
All Things Mk5
Technical Workshop
Coolant...Pls Help
